HELP I NEED Jacobson center deck pully for HR 15
   / HELP I NEED Jacobson center deck pully for HR 15 #1
randy111
ravenna ohio
jacobsen hr15
Does anyone know where i can get a center deck pully for a Jacobson HR 15 Jacobsen part #163716
It appears jacobson does not make anymore.
Thanks Randy
   / HELP I NEED Jacobson center deck pully for HR 15 #2
Randy, are the splines alright on the pulley? If so, a machine shop could weld into a new sheave. Likewise, if the splines are bad, count the splines and measure the shaft diameter to determine a replacement that could be welded in the sheave.
   / HELP I NEED Jacobson center deck pully for HR 15 #3
Thanks Randy
If the pulley grooves are still good, the center splined area is replaceable from Jacobsen. I just bought 3 of them a month ago. I can get you the part number if needed.
   / HELP I NEED Jacobson center deck pully for HR 15 #4
Can you forward the part number for Jacobsen Mower Drive Pulley center spline replacement?
Thanks,
DJ in Maryland 301-247-2193
   / HELP I NEED Jacobson center deck pully for HR 15 #5
Thanks,
I have an early serial number between 1601 and 3700. The pulley part number is 163252(obsolete), the center spline replacement is # is 337998. If you have the later machine( serial # 3701 and up) which uses the 163716 pulley, it uses a different spline. I think it is 338701 but Call Jacobsen Technical at 1-800-848-1636 and they can look it up and verify.
Hope this helps.
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
2012 GROVE TMS900E TRUCK CRANE (A50854)
2012 GROVE TMS900E...
1267 (A50490)
1267 (A50490)
2018 FORD F-150 (A50854)
2018 FORD F-150...
