OK, why can't I locate the hyd fluid drain plug?
   / OK, why can't I locate the hyd fluid drain plug? #1
sansone
Member
live oak, FL
mahindra 2615 gear
first off let me say this 2615 has been good to me for about 6yrs of mowing, bucket loading, raking and some jobs where the machine was not big enough (are they ever big enough?)..
where is the hyd drain plug? I found two large plugs in the rear but don't want to remove the wrong hardware.
this is manual tranny..looks like the gearbox and front loader share the same fluid
the two 24mm plugs on the bottom (rear axles) seem to be hyd drains, at least that's what came out..
that is all the same source for tranny, loader, correct? I wouldn't want to have empty rear axles...thank you
oh, and there was no water in there but thanks again for the suggestion
hyd filter wix $13 does that sound right? and what about this "universal" hyd oil at Tractor supply, don't we need type 32?
   / OK, why can't I locate the hyd fluid drain plug? #4
Those are the correct plugs.
Those plugs drain all of the hydraulic fluid in your tractor.
A hydraulic filter for $13.00 sounds way too cheap. You will be better off with the factory replacement. Wrong filters have caused engine failure in a 2615. As for the universal fluid, I've been using it for several hundred hours with excellent performance.
well I just found out the WIX hyd filter that cross references to the Mahindra filter ... wix# 57118 and the price is $79 (shocking)
   / OK, why can't I locate the hyd fluid drain plug? #6
That is twice the price I paid at my dealer.
ok thanks, the nearest dealer is 150 miles each way, maybe he can ship
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
