The blind hog reference hardly fits, given all the great finds you've made- boom pole, grader, plow, and cultivator- you are apparently a wizard of CL, man!
You are so right that the matching paint color is at least kinda odd, because I thought that the two of them were part and parcel.
That grader [the probable actual name for your gizmo] looks very much like some commercial ones I have seen, but those all seemed to have at least a couple of following blades behind and a little to each side of the front blade and overlapping it, presumably to spread out the gravel it had dislodged from the humps.
That looks pretty well made too, and if you weld a couple of tabs where you're going to have to cut off the back of the three point frame, you could easily reattach it if you ever needed for grading at a later date.
You could even easily attach 2 more blades further back and even make them adjustable for width [and following distance] by using mounts that slip into the existing tubes.
The fab for your plow and cultivator should be even easier if you can bolt the 3-pt frame onto them- you prolly could even do it without any welding, if that's an issue, by bolting a couple of shorter pieces of angle iron [steel] to their frames with spacing to match the 3-pt frame.
Now I gotta go and start doing tempest searches on our local Craig's Lists- what search terms did you use for all your buys?
Thanks, and congrats again!
Thomas
Thanks! Even a blind hog finds an acorn every now and then! I've decided I can't swivel it and raise/lower it at the same time, so she's staying locked down. The gizmo under the boom tip was sold to me as a scraper/leveler for a gravel drive. The point is supposed to cut the hump down that forms in the center of a gravel driveway. I haven't tried it yet. I actually bought the thing for the 3 point frame to attach to a small single blade plow and small cultivator that look to have been made for a small Wheel Horse or Cub Cadet garden tractor. Neither of them are 3 point hook ups now, they have a 6" long "C" channel drilled for a pin hitch hook up and I want to fab an attachment of some type so I can use them on my JD 4200 3 point. I had to pay $75 for that one, again, a CL find. Had to use the boom to get it off the truck and it was nearly dark, so they got to spend the night together. Odd that they were both "rust & grey". They were found well over 100 miles apart.
