Gale Hawkins
Super Member
- Joined
- Sep 20, 2009
- Messages
- 8,268
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
Wow, I'm glad I have provided so much entertainment on the forum and I appreciate each and every one of your replys. I pulled the FEL off and I am having it taken to the shop and re threaded for a larger bolt. I have ran rotella T 6 in it since I got the tractor 12 years ago and have treated it like a baby. I'm going to keep it running as long as I can and not worry about it...just my way. Why worry about what might happen. The tractor sounds like the day I brought it home and I will not burden anyone else with my mistake. Think good thoughts and thanks again....Brad
maddog69 if it was a $3000 tractor I might do the same but with your set up showing at $10K at tractor house and other places I would spend the $120 parts cost to put in new rod and main bearings while at the shop and have them fit a new plug while the oil plan was off. The time to replace these six set of bearings will not be many hours of labor I expect. I am assuming they can be replaced with just the plan removal.
New Std Main Bearing Set for Kubota D905 3 Pair | eBay
Actually with the pan off I would just pull the rod caps and look at the insert in the cap and view/feel the crank and most likely replace the bearings if there was any heat/wear damage. I would do the same with the mains but I would not expect them to be bad. It is the whamming of the piston firing with no oil film that causes the first level of damage. The main bearings do not deal with the same level of direct impact.
I would add the Archoil AR9300 or the Ceratec for sure if it was me but that might just be due to my tool and die experience many years ago.
