Reasonable grade to expect a Kubota BX 25 to climb
   / Reasonable grade to expect a Kubota BX 25 to climb #1
Martin Hache
Ottawa, Ontario
Kubota BX25
Does anyone know what maximum grade I can expect to climb with my Kubota BX 25 when equiped with a loader and backhoe attachment?
I am finding that I cannot climb some hills that I wouldn't expect to be excessive!
Thx
   / Reasonable grade to expect a Kubota BX 25 to climb #2
Why won't it climb them? Do the tires slip? Is it a matter of traction? I have found that 4wd tractors equipped with R4 tires will climb just about what I can climb on foot. In other words If I can get up and down it on foot, then the tractor will go up it. So about 30 degrees or maybe a hair steeper. I have some slopes in the back that might be 35 degrees and the last 3 tractors I have owned will go up them, but it is all you care to try to walk up or down. And if they are wet, you can forget it.
No spinning of tires. Just no forward movement. The slope I was negotiating was probably more than 35 degrees. I was wanting to get some idea of what the tractor's capacity was.
Thanks for the reply. This helps!
   / Reasonable grade to expect a Kubota BX 25 to climb #4
Were you the Low range of the Hydro?.. If in HI range the relief valve may have opened.
   / Reasonable grade to expect a Kubota BX 25 to climb #6
Any tractor in Low range should run out of traction before running out of power. Definitely something wrong if different from that.
   / Reasonable grade to expect a Kubota BX 25 to climb #7
I am inclined to agree.. In LO range, There is no scenario where I cannot spin the tires. Including pushing up against an immovable object I can spin all the tires.. It sounds like the relief valve on the hydro is set at too low of a pressure. I would get that checked out.
Will get it checked out.
Thx
   / Reasonable grade to expect a Kubota BX 25 to climb #9
Did the dealer show you how to use the HST "go pedal" properly? The HST pedal is like an infinite gear adjustment, not an accelerator as in cars/trucks. If you're flooring it, that would explain the lack of power on a slope... that's effectively putting it in a taller gear. You want to back off the pedal instead, which gives it the lowest gearing. Lots of discussions here about using hydrostats... good info if you're just getting started with one.
   / Reasonable grade to expect a Kubota BX 25 to climb #10
MY b2920 is "geared" so low in low range you can punch the HST pedal clear down and hardly move forward its really really slow. I've never ran out of power in mid range with my backhoe/fel on. Something isn't right with the tractor.
2016 Nissan Titan XD SL 4x4 Crew Cab Pickup Truck (A51692)
2016 Nissan Titan...
1264 (A50490)
1264 (A50490)
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
Skid steer auger plate (A50322)
Skid steer auger...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
