Found on CL. Not my grader.
float, box craper, grader, custom
From the ad:
"this is what i call a float, the design is mine and i custom built it. i and some other nursery men in my family use these and i desided to build another one and sell it. it works alot like box scraper, only better, its 2 4"x6"x8's with a 3/8"x1 1/2" angle embedded in the cutting edge of both beams. has a heavy steel frame that provides both strenght and the weight to dig into the ground if you want and it also has a platform to put more weight on if you need it. 25" spread between pins for lift arms. with a tractor bucket and this you can do alot, ive done slops for our yard leveled out alot of dirt and gravel. this really does work and is easy to use. come take a look at it,..."
From the ad:
