Air Compressor
   / Air Compressor
Quincy, Devair etc. are true slow speed, industrial compressors. Likely over your budget. The Devair HDi's (likely my next compressor) are approx $3k.
At $1000, your can get "slow" speed if you carefully shop around.
For size, You always "need that much compressor. " Sanders eat air. I have close to 20CFM @90PSI and wish I had 2x that when sanding and sand blasting.
That's what I'm trying to do guy;s, find a low RPM machine.
   / Air Compressor #13
   / Air Compressor
   / Air Compressor #15
Any idea what they go for?
Im not sure about American pricing, but here, the 5hp 80 Gal is about $2500ish. full retail, but can be had for less. Bare in mind this is a FULLY industrial grade compressor, full pressure lubrication. 2 stage. Capable of running 24/7 compressor. 20,000 hr warranty . It can deliver around 20 CFM @175 PSI.
The larger, 7.5hp 80gal which delivers 27ish CFM @150 psi is about $3500.
They do have a lesser line called SDi, still pretty high quality (imported single stage pumps I believe), 10,000hr warranty, for significantly less. 5hp 60gal 21cfm @90(?)PSi for $1085 OR 5hp, 80gal 24cfm for $1895.
Here's a Carquest flyer with them in it FYI. Use the Carquest prices as a guide. Usually their prices are high. 2013 CARQUEST Tools & Equipment - Q2 - Canada - 0015
   / Air Compressor #16
I agonized over a purchase selection for many days last year. The tools I was getting called for 9 cfm @ 90 psi, so I wound up having to buy a 60 gallon unit with more than 2 HP to get that kind of air delivery. The one I wound up with is a Campbell Hausfeld unit, and the best price I found on it was from Tractor Supply. Here is a link: Campbell Hausfeld® 60 Gallon Cast Iron Air Compressor - Tractor Supply Co.. They had none in stock, and ordered it in for me.
Whatever one you buy, look it over carefully before you accept it. The first one I got had fallen over, and the mounting bracket on the top of the tank was bent backward at about a 15 degree angle. I felt like I was taking a risk with the welds cracking, the compressor discharge line was stressed, and the belt cover was broken in several places (both inner and outer covers). The damage was not obvious until we removed the plastic bag they had it wrapped in, which was still stapled to the shipping pallet. Tractor Supply ordered me a replacement unit and exchanged it without any problem.
   / Air Compressor #17
Murphy: I started a similar thread last year when shopping. And my budget was initially set at about 1000, as you suggest yours is. I got an education from the TBN guys here: http://www.tractorbynet.com/forums/...-air-compressor.html?highlight=air+compressor Enjoy the thread, LOADS of good education in there.
I eventually spent more money than I planned to (see post #92), but got a lot more for my money, and all USA made.
   / Air Compressor #18
About a month ago my compressor died and i decided to get a bigger one. I had previously looked at the 60 gallon kobalt at lowes and had made my mind up to go with that when i was readly to get one. I hooked up the trailer and headed on out to lowes. Went around the store picking up other items that i would need to hook it up, then headed for the tool section to get someone to bring one to the front for me. I turned the corner and "WOW", right before my eyes was the exact compressor i came to get with a 249.00 priced tag on it. According to the person working there it was the old model. It pays to look around, i got lucky, but so may you.
   / Air Compressor #20
Have you picked out a color yet? My 5hp Speedaire keeps on running but when it does die one of the brands I'll be looking hard at is Eaton. I would like to upgrade to a 10hp single phase compressor that should last my lifetime and have more than enough air for anything I may want to do.
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
YANMAR ViO45-5 EXCAVATOR (A51406)
YANMAR ViO45-5...
