Hydrualic Oil versus Motor Oil
   / Hydrualic Oil versus Motor Oil #11
I have a unit that calls for Castrol 20W50 synthetic Motor Oil only for the hydraulic system.
Chris
Ouch, that could be expensive if it holds a lot. . .
My Kenworth's transmission takes a 50W synthetic oil that cost over $30/gallon. What did you say, Ouch?
But, the oil change interval on that transmission is 500,000 miles.
I think I can run everything with ISO 46 hydraulic fluid and then have all my engine oil be 15W40 Mobil 1 Delvac. The guy at the dealership yesterday told me I would ruin my tractor engines and hydraulic systems if I didn't use Case or New Holland brand fluids. :laughing: He said Rotella and Delvac is a sure way to ruin them :rolleyes:
That should simplify it. Right now I've been using the same engine oil, but I've got all kinds of different hydraulic fluids.
   / Hydrualic Oil versus Motor Oil #13
I have a good customer that buys nothing but new Kenworths and he drains the synthetic out of the trans and puts standard gear lube back in!! Put a PTO on a new unit and wanted to top the tranny off, so I asked him to bring me some oil and when he showed up with 85/140 that stirred a few questions. Maybe you can't teach a old dog new tricks!. CJ
   / Hydrualic Oil versus Motor Oil #14
85/140 will probably be ok. That's his choice, but the manufacturer of my transmission, Eaton RoadRanger, designs it to use the 50w synthetic. I'll go with their recommendation.
   / Hydrualic Oil versus Motor Oil #15
Yea, that's what I tried to tell him, but hey he gets 500 to 700,000 miles out of them so you can't really fault him for using what works. CJ
   / Hydrualic Oil versus Motor Oil #16
Ouch, that could be expensive if it holds a lot. To the OP, Basically like JJ said it all comes down to weight and the additive package. One of the mechanics around here always said any oil is better than no oil!! A lot of truth to that. CJ
Holds about 2 gallons. Not a big deal.
Chris
   / Hydrualic Oil versus Motor Oil #17
My D3 specified regular 20w motor oil for the hydraulics...
   / Hydrualic Oil versus Motor Oil #18
Make sure you know what you are asking for or want. There is no Mobile Delvac 1 15w-40. Philip.
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55218)
2015 Freightliner...
2004 TerraGator 8104 (A55301)
2004 TerraGator...
20" Sea Container (A47384)
20" Sea Container...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
