I have both. A shear on my 4' cutter and clutch on the 6'. I have no problem with the shear bolt system. The clutch is more temperamental as far as adjustment. Not setting the slip clutch too tight takes some practice. But it sounds that you have experience with your tiller.
The most ideal drive line protection for you is dependant on what you will be hacking down. If just heavy grass and weeds and one inch and smaller saplings, my reccomendation is shear bolt. That is assuming your cutting area is free of damaging debris (big rocks, stumps, concrete blocks ect). If you will be regularly chopping brush to max rating for the cutter, or in a debris field, you may wanna go slip.
It also depends on how you store your cutter. If you have a slip clutch and the cutter is stored outside, the clutch should checked/inspected every use to insure it WILL slip in need and not rusted locked.
35 hp sounds a little on low end for a 6' cutter, but it all depends on what you are cutting.
Cheers!
