Aluminum boat weld question
   / Aluminum boat weld question #23
Many years ago, my cousin's pontoon boat did have drain plugs on the back end of each pontoon. But I haven't seen a pontoon boat with such drain plugs in a long time, and I've never seen one with vents. Of course, that's not to say such doesn't exist.
   / Aluminum boat weld question #24
our family pontoon ( 20ys old ) has then drains too.
i had no clue new ones had no drain... hmm... not sure i like that 'feature'...
   / Aluminum boat weld question #26
If you go with the Zinc based half round with flat side rods.. Don't over pay. I've seem them for $3.00 each at shows. You can pick them up for $3.00 per # at your LWS.. Ask for Welco 52 and save some $$$
   / Aluminum boat weld question #27
I've seen pontoon boats equipped with Schrader valves. Pretty good idea to me. 4 or 5 pounds of pressure would be a good indicator of a leak while in the water.
   / Aluminum boat weld question #28
When they built aluminum fuel tanks at work they would fill the tank with water and then pressurize it with no more than 3-5 psi. Any more than that and you are creating a bomb...
   / Aluminum boat weld question #29
I used to build large oilfield tanks and they were tested at only 1 1/2-2 PSI. That doesn't seem like much pressure at all but when they let it out through a 3/4" valve, you'd swear there was 200 PSI coming out!:shocked:
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
2012 INTERNATIONAL MA065 FLATBED (A53426)
2012 INTERNATIONAL...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
