2410 lower lift arm replacements
   / 2410 lower lift arm replacements #1
Pixguy
Super Star Member
By the lake in NH & FL
2011 MF 2410 TLB
My lower arms are bent and although they work fine, I'd like to get replacements for them. Anyone have a good source for them?
   / 2410 lower lift arm replacements #2
Not sure… who handles M-F parts now that Northwood no longer does? Not sure which lower lift arms you're referring to, but it sounds like factory parts might be the best way to go. ijk
Not sure what they are called by MF but the lower arms on the 3ph, one is adjustable. I guess I'll have to contact the dealer in New Boston. I've seen them at TSC but they carry the big boys. Thanks
   / 2410 lower lift arm replacements #4
OK, I got it. Four options, perhaps:
1. They're "just" steel rods- first thing I'd do is lay them on something and pound on 'em. Maybe a torch would help. Nothing to lose, and they might very well come into it.
2. M-F parts as replacements.
3. I'd be willing to bet that, if you don't mind orange, Kubota parts might be interchangeable. Worth a look.
4. Somebody must make generic Cat-1 replacements (?).
In the M-F parts book, those are called "lift rods." There are two types, "L-type" and "Except L-type". From the drawings, it appears the L-type lift rods are all straight, where the "Except L-type" have a bit of an offset angle at both ends. For what it's worth, mine is a 2007 model and uses the straight "L-type" parts. Not sure why the change, but there it is. To repeat-- when looking at the part numbers, the straight ones are the "L-type."
Here's some pics:
   / 2410 lower lift arm replacements #5
Oh, and I should add-- my tractor's a 2310, and the part numbers are from the 2310 book… but they MAY be the same as the 2410, you'll have to verify. Sorry, I hadn't paid attention to your tractor's model. (Getting' old, I guess!) ijk
No apology necessary, they appear to be the same and your help is greatly appreciated. :drink:
   / 2410 lower lift arm replacements #7
You are entirely welcome; glad to help. :thumbsup:
2005 John Deere 330CL (A55272)
2005 John Deere...
17102 (A56859)
17102 (A56859)
3 HOLE FOOD WARMER (A58374)
3 HOLE FOOD WARMER...
2013 BMW X5 (A56859)
202481 (A54757)
202481 (A54757)
LAWN AERATOR (A52708)
