Cutting off protruding roofing nails - Damage roofing?
   / Cutting off protruding roofing nails - Damage roofing? #1
JRobyn
Elite Member
Middle TN
Kubota L4330HST
Hi guys,
So I'm decking in a nice big section of attic (8' x 15') with a sloped roof over it ranging from about 4ft to 12ft high. In the lower areas, I'm thinking of cutting off any protruding roofing nails using a thin cutoff wheel in a disc grinder. Obviously, the nail shafts will very briefly get quite hot, so I'm worried about the heat damaging the roof shingles or their underlayment. I'm not sure if the underlayment is roofing felt or plastic membrane or both. I think just felt. The roofers used some heavy poly membrane, but I think that was only under the tin, and this part of the roof is all shingle.
The decking is nice thick 23/32" Plytanium, so it should provide a decent heat sink.
Anybody done this? Any roofers out there with an opinion? How much chance is there of any heat damage?
- Jay
   / Cutting off protruding roofing nails - Damage roofing? #2
Go for it.
   / Cutting off protruding roofing nails - Damage roofing? #3
Right after cutting the nail, hold a wet rag on the stub. It'll draw off most of the heat.
   / Cutting off protruding roofing nails - Damage roofing? #4
There is not enough heat generated to worry about. You can just about hold one in your hand after cutting it with a thin disk. It will never get hot enough to melt asphalt.
GO FOR IT>
   / Cutting off protruding roofing nails - Damage roofing? #5
If you are still worried about the heat - use a large side cutting pair of pliers. There are special types with angled jaws made just for that type job.
   / Cutting off protruding roofing nails - Damage roofing? #6
If this is just to keep from sticking your body parts on the nails, what about just "wacking" them so the ends fold over? This way there is less chance of nails "working loose".
That was my first inclination, but unless they are REALLY whacked flat, doing this still leaves a dangerous point exposed, and I figured that whacking them really flat would actually put a lot of vibration/motion into the head of the nail where I least want it, especially risking that I actually drive them back out enough to raise the nail heads. A quick cut should disturb the nail shaft very little (except for the heat). I thought of a mechanical cutter/nipper too, but a lot of what I'm concerned about are nails that are broken out the side of the rafters where the framers missed getting them centered. These are hard to get cut clean, but with the disk, I can cut and buff them flat or slightly recessed against the rafter.
- Jay
   / Cutting off protruding roofing nails - Damage roofing? #8
Covering the nails would be an alternative to cutting. You could rip pieces of 1" styrofoam on a table saw to fit between the rafters. The protruding nails will help hold it in place, there are also adhesives for foam that come in std. caulking tubes. Or, there is spray foam insulation to consider--if that works with your other insulation and vapor barrier situation.
Of the cutting methods, the cut-off wheel sounds the best to me.
   / Cutting off protruding roofing nails - Damage roofing? #9
I mostly use oversize end cutters... not much exposed after that.
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
UNUSED GREAT BEAR FORKLIFT JIB (A51248)
UNUSED GREAT BEAR...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
