Replacing a gear in my transmission.
   / Replacing a gear in my transmission. #1
kwdumes
Port neches, texas
farmtrac 300dtc
I have a Farmtrac FT300DTC. I need to replace a gear in the gear box. My question is:
Where do I split the tractor in half at, between the motor and trans, or between transmission and gear box? Also where can I find a service manual for this tractor? Thanks.
   / Replacing a gear in my transmission. #2
Did you ever get your trans apart?. I have to do the same with mine. I just put it back together from a clutch install that didnt fix it. The shuttle shift( forward/reverse lever would not move anymore to place it in gear.. Thanks.
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
UNKNOWN 16 T/A TRASH TRAILER (A53843)
UNKNOWN 16 T/A...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
