Replacing a gear in my transmission.
   / Replacing a gear in my transmission. #1
kwdumes
Port neches, texas
farmtrac 300dtc
I have a Farmtrac FT300DTC. I need to replace a gear in the gear box. My question is:
Where do I split the tractor in half at, between the motor and trans, or between transmission and gear box? Also where can I find a service manual for this tractor? Thanks.
   / Replacing a gear in my transmission. #2
Did you ever get your trans apart?. I have to do the same with mine. I just put it back together from a clutch install that didnt fix it. The shuttle shift( forward/reverse lever would not move anymore to place it in gear.. Thanks.
2008 CAT D6T DOZER (A55745)
2008 CAT D6T DOZER...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
294 (A52706)
294 (A52706)
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
