Shortest oil filter for Yanmar?
   / Shortest oil filter for Yanmar? #1
California
Super Star Member
An hour north of San Francisco
Yanmar YM240 Yanmar YM186D
I need an oil filter with the shortest can for my YM186D.
The (optional) power steering cylinder hits the oil filter occasionally and has dented it. I'm concerned the filter will get punctured.
What's on there now is the standard Hoye filter. Anything a quarter inch shorter would be better.
I recall #1334 and 1064 were suitable for the YM Yanmars but I don't recall which was shorter. I think the short one was #1334 and is the same filter used on my '99 Subaru.
Any advice?
EDIT - I hate to post misinformation. 1064 is shorter than 1334. Both were specified many years for Honda, Subaru etc so they are sold everywhere.
   / Shortest oil filter for Yanmar? #2
Can you get Sakura branded filters over there? They are little stumpy things and keep well away from everything. The Baldwin is 1" maybe more longer than the Sakura that i use. I find them readily available here and they work well on the YM's. I will look up and see what else they fit ( i think the number is C-1032 from memory)
   / Shortest oil filter for Yanmar? #4
Here are the heights listed of the filters mentioned in the first post and one shorter that may work (1365).
Thread Size: 20X1.5 MM
Max Flow Rate: 9-11 GPM
Heights
1334 - 3.194"
1064 - 2.944"
1365 - 2.577"
More specs available on fleetfilter.com
   / Shortest oil filter for Yanmar? #5
but what about the valve pressure on those and the micron filtering on all those?
   / Shortest oil filter for Yanmar? #6
I left a web address at the bottom of my last post where you can look those up and check those. I don't know what the pressure or micron requirements are.
You guys are amazing! Those links led me to the information I needed.
I didn't know that Katahdin's #1365 existed. That one really is tiny, the diameter looks no larger than its sealing gasket and with 2.577" height it will easily give the clearance I need.
There is little difference in specs for those three filters. I'll buy a #1365.
With a smaller can this one must have less filter surface but with 50 hour filter changes it should be fine - considering that Yanmar specifies you can change the filter after 2~3 oil changes depending on use.
Thanks!
Links (fleetfilter.com) for anyone interested:
1334 - 3.194"
1064 - 2.944"
1365 - 2.577"
   / Shortest oil filter for Yanmar? #8
i see that the 1365&1334 by passes at 8-11 psi and the other 1064 bypass at 16 its possible that they will bypass when the latter is still filtering but if its bypassing you have a clogged filter and have mostlikely gone way over your oil change interval anyway, pointing out you dont care about your equiptment anyhow.
Yes, I saw that spec but didn't think it was relevant. I can't imagine running an oil filter - maybe for years - until oil won't pass through it.
Maybe the bypass spec is more significant for someone who runs single-weight oil below its intended range in cold weather?
   / Shortest oil filter for Yanmar? #10
good point on the oil....i would agree that is more likely, someone running say straight 30wt or something in alaska?
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
Long 35 Tractor (NOT RUNNING) (A50775)
Long 35 Tractor...
