Sodo : Been around this forum for some time and I Believe what S.A. , Arc , Mike and others are talking about as far as 110 / 120 welders is more about What Questions Members , ( be they new or otherwise ) , Ask and also What The Given Situation is for those that may ask . Example , They may have 220 / 240 to a barn or garage and plan on welding heavy metal , ( 3/8" or bigger ) or heavy equipment , etc.... . Those that may ask may also state that they may start out on small metal but go bigger as they gain experience . Thus it is not so much that they don't like 110 /120 welders , it is more like saving someone money by only buying maybe a more advanced welder now , than having to upgrade later . ( Not Putting Words in any of Their mouths , Be it S.A. , Arc , Mike , etc.. , Just My opinion on what I have read of their threads ) .
I Do own a 110 /120 Welder . A Lincoln SP135+ model , that I used for several years burning .035 fluxcore . Welded up to 1/2" with it on several projects around the place here , including converting a home made single gang disk into a 6' wide , 8 shank Ripper that has hooked many items under the surface and pulled the TC 30 front end off the ground even with a loaded FEL . None of those welds have ever broke . I can promise Though that even my Best Looking Weld , cannot compare in Looks to any of those I mentioned , Worse Welds . :ashamed:
That Being Said , I Knew The limitations of the machine duty cycle wise when running that high or maxed out , thus I matched that duty cycle by taking a lot longer building those projects by doing other things . Were as If I had been using a 220 / 240 machine , Projects would of been done much quicker .
I kept that Lincoln , even though I now also have a Longevity 200S mig / stick welder . My Brother has a Miller 212 but also has their 140 auto set machine . Which We actually just used a few weeks ago converting 3/4" galvanized pipe in to chain link fence gates , ( Yea , Yea , I know about welding Galvanized , never said I was smart
) . The 140 was great since it was very portable to take out to the already installed fence and install permanent new gate's and hinges .
I personally Just believe they are trying to " Help " people be better welders and save people money in the long run based upon statements that a member may put in their threads . No Harm , No Foul . Again , Just my :2cents: .
Fred H.
BCP : You know the Lady ?? You are 100 % Correct , in Jail but still Thinks She is Right ?? Thought I was a few cans Short of a 6 pack
