Rotary Mowers
   / Rotary Mowers #1
styr
Atlanta, GA
John Deere 770
I have a JD770 and need to know what size rotary mower to buy
   / Rotary Mowers #4
Your tractor has 2O PTO HP and is 54" wide according to TractorData.com John Deere 770 tractor information. I am not sure what type of tires are used to measure the width (e.g., R1 vs. R3).
It would be best to have your mower at least as wide as your tractor, so a 5' model would fit. However, the rule of thumb is 5HP per foot of mower width, so 4' would be appropriate. However, each manufacturer will list the recommended HP for each of its mowers. To illustrate, I am currently in the market for a mower to fit a Kubota B2320. Bush Hog has a 4' model that requires a minimum of 15 HP. Their lightweight 5' model requires 25HP. See BH10 Series Rotary Cutters.
The manufacturer HP minimum requirements may be conservative. You may be able to handle a 5' model in cutting light material. You may have to add front weights if you don't have a FEL.
Steve
PS -- I assume that you are asking about a rotary cutter rather than a finish mower.
   / Rotary Mowers #5
You have 20 horsepower at the power take off. The usual standard is 5 HP per foot. So that works out as 4 feet for you. However....ahem.....if your doing lighter cutting, willing to go slower, willing to maybe keep your blades sharper, willing to mow a bit higher, willing to take a partial cut in thicker stuff you can get a lighter duty 5 foot one to work for you. You'll need weights on the front of your tractor EVEN if your mostly level. For real. Get front weights. A Landpride 1860 is a nice choice as its really 4.75 feet wide and comes in green!
   / Rotary Mowers #6
Darn it! Stonypoint beat me by a minute!
   / Rotary Mowers #8
If you have a problem with a 5' 'hog mowing grass, sharpen the blades.
   / Rotary Mowers
Great Forum thanks all for your help .
Only need to cut grass pastures so may try the 5 footer
It also has the turf tires which make it some what wider not sure if that works on the outside or the inside .
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
2015 Toro Reelmaster Gang Mower (A55851)
2015 Toro...
10 GALLON SANDBLASTER (A54757)
10 GALLON...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
