HELP/OPINIONS/IDEAS -TRAILER AID PLUS ?????
   / HELP/OPINIONS/IDEAS -TRAILER AID PLUS ????? #1
bullbreaker
Elite Member
SW FLA
D Ranchers daughter'$
Was going to do some traveling on/in my travel trailer. I have unit fully maintained in great shape , but wanted thoughts/opinions/advise on if Trailer Aid/ Plus was way to go. As far as ease and not damageing travel trailer in case of flat tires.
I own a Craftsman 7 ton portable jack and a highlift off road jack. My concern is damageing axles ext.
I have a Heartland model with wide track (26 lrss) no problems with it so far. I never overload my trailers.
Amazon.com: Trailer Aid Plus Tandem Tire Changing Ramp: Automotive
Amazon.com: Hi-Lift Jack HL484 48" Hi-Lift Black Cast and Steel Jack: Automotive
Anyone swear by Trailer Aid/ TA PLUS ????? Or other homemade ideas or options ???? Thanks in advance !!!!
   / HELP/OPINIONS/IDEAS -TRAILER AID PLUS ????? #2
Don't use this on any trailer. I have dealt with customers trailers and what happens is you overload the good tire/axle and bend the spindle. I have fixed a few.
Chris
   / HELP/OPINIONS/IDEAS -TRAILER AID PLUS ????? #3
A bottle jack of sufficient tonnage is what I would recommend. Small relatively light weight and easy to use and store
Sent from my iPhone using TractorByNet
   / HELP/OPINIONS/IDEAS -TRAILER AID PLUS ????? #4
I could not agree more. I carry a 6 ton bottle jack, folding 4 way lug wrench, 2 pieces of 2x6 about 8" long, and a piece of 4x6 about 8" long in each of my trucks. Best $30 one can spend at HF.
Chris
   / HELP/OPINIONS/IDEAS -TRAILER AID PLUS ????? #5
Well I have and have used for years on gooseneck horse trailers. Must have changed at least 15 or so tires using it. Jacking up a trailer with 2 or 3 horses inside jumping around with a bottle jack ain't for me.
I have never need to use it on my 5th wheel. A Heartland Big Country. But if you jack that Heartland with a bottle jack you must jack it by the frame. If you use an axel you will bend it.
   / HELP/OPINIONS/IDEAS -TRAILER AID PLUS ????? #6
If you are using a trailer aide, I'd recommend a metal one. I've never known plastic to hold up all that well.
   / HELP/OPINIONS/IDEAS -TRAILER AID PLUS ????? #7
I've had one for a few years. Have used it probably 4 times on a couple of trailers, a 7x14 enclosed and a 7x18 enclosed. Neither trailer was near capacity. No problems to date.
   / HELP/OPINIONS/IDEAS -TRAILER AID PLUS ????? #8
I agree with Jimbrown. Have used things similar to the trailer aid (usually an angled 6X8) to change tires. I believe Chris if he says he has had to repair, but if we are going to bend a spindle it would be pulling a full load of Christmas trees out of a frozen rocky field with a heavy tractor. Not unusual to have at least one tire off the ground, just like driving over a curb. To me, that is much rougher than easing a trailer on a block to be able to safely change a tire on a steep slope or with moving livestock.
I want to thank all of You's so far for your opinions which I respect and your shareing of your experiences. I am thinking Iam just gonna stick with what I own and use the bottle jack method properly placed and heavy wedge of wood etc. A major factor in my decision was also my TT has what they call wide/track axle system.
I wanted to respond to tread soon because I've read many threads/posts and many sites includeing TBN where it seems like once a poster received help/advice and fixed his or her problem there was never a follow up or a response as to if and how it worked out.
And yes I know its not a perfect world !!!!!!!!!!
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
