6 ft.Rotary cutter verses 5ft. ???
   / 6 ft.Rotary cutter verses 5ft. ??? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
I have a 5ft taylorway standard duty rotary cutter I now use behind my 2012 kioti DK40HST.I am looking to purchase a medium duty,60hp gear box,twin tail wheel King kutter professional series 6 ft. rotary cutter.The weight of the the cutter is 1,245 lbs my concern will my tractor handle that weight ok?Anyone own or cut with this model cutter?Thanks.
   / 6 ft.Rotary cutter verses 5ft. ??? #2
I had a DK 35 and a Woods BB72 that weighed 800 lbs and it handled that OK but that cutter you mentioned is 50% heavier. It was a little "bouncy" when raised because a cutter is quite long and the weight is quite a bit further back, than say a box blade.
I think your concern is a valid one and would ask the dealer to try it out first, it's probably a bit too much. Good luck!
That's kind of what I am thinking also.The front end loader will stay on the tractor while brush cutting so maybe that would be a good counter balance?
Looking at the 5ft woods BB600x rotary cutter also.Any thoughts?
   / 6 ft.Rotary cutter verses 5ft. ??? #5
I have a hardee 6 foot bush hog and Woods RM990 I run behind my Kioti 45. Bush hog is easy for Kioti. The woods works but I mow with loader on and still hit the 4x4 button when backing up or turning sometimes. I really like the Woods as cut is much better and if grass is thick I can slow down. Not sure what woods weighs but it is a tank.
   / 6 ft.Rotary cutter verses 5ft. ??? #6
My Kioti 72 RFM weighs 661 lbs, and the DK45 doesnt even know its there with foot high grass.
Ended up purchasing a Bush Hog Model BH16(6ft.) rotary cutter today,65 hp gear box and weight 764 lbs..Dealers going to deliver it next week.
   / 6 ft.Rotary cutter verses 5ft. ??? #8
I think that's a better fit for your machine.I just purchased a Landpride 6ft.that weights at 719 lbs behind my L4240 and it's a good fit,you will know it's there when raised.
I agree, I was **** bent on buying a medium/heavy duty cutter but for what I am cutting (field grass/small brush)I believe this cutter will fill my needs.
   / 6 ft.Rotary cutter verses 5ft. ??? #10
I bought that exact same mower. I've only been able to use it a couple times for short periods but I like it a lot. It's currently being run behind a 5325 (55 pto hp) and it does fine. Probably a little overkill but I bought it to run behind a smaller tractor I will be buying in the future and because I got a great deal on it.
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
Spartan RT-HD Zero Turn Mower (A59814)
Spartan RT-HD Zero...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere X30 Riding Lawn Mower (A59814)
John Deere X30...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
404 (A52706)
404 (A52706)
