grsthegreat
Super Star Member
i install lots of whole house generators...doing 2 this week alone. You need to do some load calcs.
1. are all major appliances gas or electric
2. is there a well or sewer pump
3. square footage of house and lighting load
4. can you easily isolate the heavy use loads
5. can you easily install a transfer switch.
all this needs to be taken into count in determining generator size
personally, i wouldnt use as tractor mounted generator cause every time power has failed at my place, its been in the dead of winter and ive needed the tractor for other stuff...like snow removal
oh, and my house has a whole house generator system and it gets used more times than i like to think. We seem to lose power for as long a 1-2 days several times a year. I actually went ahead and installed a manual transfer switch in my shop with a 30 amp exterior plug cause the last time i couldnt open my rollup door for 3 days except manually...and that sucked. Also, my air compressor went dry,and had to take trailer to service station to air up tire. I rely on my equipment too much to be left without power.
My current backup system will only power the house. It doesnt have enough power for the other 2 buildings attached to the same power source, and doesnt link to the basement...which wasnt completed when system was installed.
As i am now a Generac dealer and installer, my next plan is to install a quiet source 22KW unit... or might possibly drop to the new 22KW air cooled unit with automatic 200 amp transfer switch. This unit would power entire house AND the barn. Last major power outage my horse water troughs froze and it was a pain in the butt to fix the damage.
but i never have the time to work on my own stuff anymore.
