Did this u-bolt come from Kioiti DK40SE or Backhoe?
   / Did this u-bolt come from Kioiti DK40SE or Backhoe? #1
spindlewood
Northern Idaho
Kioti DK40SE HST Cab
I spent a couple of hours today getting stumps out and found this 4" u-bolt on the ground where I was working. I can't imagine what else it could have come off of besides the tractor or backhoe, but I also have no clue where a u-bolt would be used. Any ideas?
   / Did this u-bolt come from Kioiti DK40SE or Backhoe? #3
It looks like the U Bolt that is used to corral the hyd hoses near the back hoe hinge pin. MY DK35 hs two of them, guides the hoses from the tractor to the back hoe hyd cylinders.
   / Did this u-bolt come from Kioiti DK40SE or Backhoe? #4
Agreed
Thanks to both of you. With the help of the picture I was quickly able to find where it goes. The hoses covered the holes, so I doubt I would ever have figured it out without the picture - 1000 thanks for taking the time to post it.
Makes me wonder just how many parts will vibrate loose. Some things like the throttle they over torque so I can't smoothly change the rpn. And then there are the bolts and screws that I find on the ground... This is number 4.
   / Did this u-bolt come from Kioiti DK40SE or Backhoe? #6
.[/QUOTE]Makes me wonder just how many parts will vibrate loose. Some things like the throttle they over torque so I can't smoothly change the rpn. And then there are the bolts and screws that I find on the ground... This is number 4.[/QUOTE]
On my DK 35, I check bolts, clips and pins often, they seem to shake loose/off constantly. Of course, I use mine in the bush and on rough terrain so to be expected. My FEL bolts are the worst for shaking loose. 3PH clips and pins are also frequently AWOL after a days bush hogging.
   / Did this u-bolt come from Kioiti DK40SE or Backhoe? #7
Make sure you check the bolts which hold the backhoe to the subframe. Mine are constantly shaking loose! :eek:
   / Did this u-bolt come from Kioiti DK40SE or Backhoe? #8
Bolts? My backhoe is held on by two taper pins through sub-frame. I do check the sub-frame to tractor bolts regulary.
   / Did this u-bolt come from Kioiti DK40SE or Backhoe? #9
Taper pins hold the subframe to the tractor, I'm talking about the backhoe to subframe.
2014 CHEVROLET IMPALA 4DOOR SEDAN (A56138)
2014 CHEVROLET...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
Step Ladder (A47477)
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
