Need three foot, small bush hog for my 135d. Any suggestions?
   / Need three foot, small bush hog for my 135d. Any suggestions? #1
ssg510
So I am in need of a small bush hog for my 135d, Anyone know where I can get one this small. Will the 135d handle it ok. Thanks
   / Need three foot, small bush hog for my 135d. Any suggestions? #2
The smallest I have seen is a 42 inch King Kutter at tractor supply. However I noticed they don't seem to make it any more. Sorry I am not finding anything smaller.
   / Need three foot, small bush hog for my 135d. Any suggestions? #3
The smallest I have seen is a 42" model from Land Pride -- the RCR1542 (RCR15 Series Rotary Cutters | Land Pride. That unit weighs 402 pounds and has a recommended minimum of 20 HP. That's probably more than your tractor can handle.
There may be smaller units, but I haven't seen them.
Steve
   / Need three foot, small bush hog for my 135d. Any suggestions? #4
check agrisupply? i had seen them online before at TSC like others had mentioned.
Just checked agrisupply, found this 40" model..its $900 though thats pretty pricy!!! but you dont have many options in a small size!
40 3-Point Rotary Mower Category 1
   / Need three foot, small bush hog for my 135d. Any suggestions? #5
His tractor is 16 engine horse (PTO power not given), and weights 1100 lbs.. He needs about a 3 foot cutter.. I havent seen one. Not saying you couldn't make one, but that is an awfully small tractor to be doing much brush hogging.. It would likely get hung up on a 2 inch sapling.
   / Need three foot, small bush hog for my 135d. Any suggestions? #6
Have you considered a pull type that is powered with it's own engine? I was thinking that might work better for you.
Thanks for all the help. Looked on the Howse site and they make a 3 ft rotary mower also. Weighs 375lbs. and is rated for 10-20 hp. The bush hog sq142 is 397lbs and also rated for 10 to 25 hp. Any one have any time with howse equipment? any good. I found a slightly used bush hog sq142 for about $700 what do you guys think?
   / Need three foot, small bush hog for my 135d. Any suggestions? #9
I have had a 4 ft Howse rotary mower for 8 (?) years now. It works fine. I think the quality is similar across all the 'compact' brands.
I use it behind both tractors (see sig, below). The YM186D is sufficient to power it everywhere except going uphill in waist-high wet grass. That requires taking a lesser cut, say 20 inches, instead of a whole 4 ft cut. There's one poster on here running a 5 ft rotary mower behind a YM186D!
If 42 inch is the smallest standard size for a rotary mower, that's what I would buy long as you can get a return guarantee (returned unused) in case the tractor can't lift it. And I don't expect that to be a problem.
Here's an old thread showing my mowing rigs.
I think the greater productivity of a mower as wide as you can lift is worthwhile, even if occasionally you can't take a full width cut with it.
   / Need three foot, small bush hog for my 135d. Any suggestions? #10
I have a Land Pride RCR1542 on my Kubota BX1500, handles it just fine with no issues.
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2017 FORD F550 XL BUCKET TRUCK (A51406)
2017 FORD F550 XL...
Kubota ZG327 (A50120)
1261 (A50490)
1261 (A50490)
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
