Rear Axle Oil Change Ford 445 A
   / Rear Axle Oil Change Ford 445 A #1
ktovar
Lake Elsinore Ca
Ford 445 A
I had a major screw up and accidently drained my rear axle oil by pulling the PTO shaft out not realizing all the oil would come pouring out!!! Oh boy did it ever.
I found the oil fill plug at the top of the rear axle behind the seet. Can anyone tell me how to check the oil level as I am adding oil to the rear axle? Is there a weep plug that I need to remove someware?? Please help, I don't want to over fill the axle.
Kevin
   / Rear Axle Oil Change Ford 445 A #3
Level plug is a 1/4" pipe plug with either a male square head or female hex (allen) head. Located on the RH side of the rear axle housing ahead of the RH trumpet housing and above the difflock pedal .
   / Rear Axle Oil Change Ford 445 A #4
Hey Kevin, the transmission and rear end are combined there is a plug on the right side of the trans most likely a square headplug. This is the fill level and it requires THF. (. Tractor hydraulic fluid) i got the info from my local Massey Ferguson dealer. I have a question, have you had any problems with an axle locking up? Thanks, Kevin M TaterK
   / Rear Axle Oil Change Ford 445 A #5
Your Massey dealer should stick to a brand he knows about.
Transmission and rear axle are not 'combined' on any 3 cylinder Ford tractors. I think I just figured out why your RH planetary gearset is toast.
   / Rear Axle Oil Change Ford 445 A #6
What type of oil should be used? Also, where does the transmission and rear end separate?
   / Rear Axle Oil Change Ford 445 A #7
Use New Holland 134 hydraulic oil or the equivalent. They separate exactly where the two castings are bolted together.
   / Rear Axle Oil Change Ford 445 A #8
Thank You!
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2016 Ford F-750 14FT Flatbed Truck (A52377)
2016 Ford F-750...
2017 Polaris 500 Ranger Diesel Utility Cart (A53421)
2017 Polaris 500...
