Rotary Cutter Do brush hogs come with 4 blades instead of two?
   / Do brush hogs come with 4 blades instead of two? #1
HarryN
Gold Member
Covington, Louisiana USA
1999 Bobcat 763F John Deer 850 Grasshopper 723K H2
Wondering if brush hogs / rotary cutters come available with 4 blades instead of the two?
Any advantage between them?
Never saw one with 4 blades. So, not sure if they even make them!
   / Do brush hogs come with 4 blades instead of two? #2
I have never seen anything but two blades.
If you think about the mechanics of how the blades swing around when they hit an obstacle like a tree stump, I doubt a 4 blade setup could work.
   / Do brush hogs come with 4 blades instead of two? #3
I have never seen or heard of one, and like the other poster, I don't see how it would work very well.
   / Do brush hogs come with 4 blades instead of two? #4
Might have to get one from Australia. :)
XHD Series | FieldQuip
Brushcutter Slasher | Bobcat | Earthmoving Attachments | Himac Skid Steer Attachments Australia
Three blades:
NEW Bomford folding tri wing slasher<br /> 4.6 meter cut, 3 rotors - 3 blades each with stump jump pan.....<br /> Rear axle suspension, Heavy duty aircraft tyres, level lift.
Bruce
   / Do brush hogs come with 4 blades instead of two? #5
Brown is the only domestic rotary cutter that uses four blades that I know of.
   / Do brush hogs come with 4 blades instead of two? #6
See, I learn new things every day!:)
   / Do brush hogs come with 4 blades instead of two? #7
There are several available with two spindles, and for blades (2 per spindle).
On a rotary cutter you want larger, heavier blades to be able to cut larger brush, so four blades wouldn't really help.
   / Do brush hogs come with 4 blades instead of two? #8
I thought woods made a finish type deck with swing blades like a bush hog
   / Do brush hogs come with 4 blades instead of two? #10
I have an old Woods Brush Bull 7ft drag (drawbar pull) single spindle bush hog. The "stump jumper" has four holes for attaching four blades. It currently has two. If you remove/unbolt the left side and install the four "banana shaped" blades you could cut hay.......sort of. The blades would discharge it out the side and some to the rear.
Deere 331G (A53317)
Deere 331G (A53317)
1985 Miller Wildcat 350-D Welder (A55851)
1985 Miller...
2019 LOAD TRAIL REM GOOSENECK (A55745)
2019 LOAD TRAIL...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A55745)
2004 FREIGHTLINER...
