Plastic pipe for underground?
   / Plastic pipe for underground? #31
I'm still studying what I need for the project.
Here's a pdf showing HDPE is far more able to stand surges and water hammer compared to PVC pipe.
But I'm concerned by the comment above that gophers prefer HDPE over PVC. Has anyone experienced chewed pipes?
Howdy,
I think you should go to the local supply store and look at the black plastic pipe (HDPE Pipe) You will want the higher PSI rating style, and after looking at it, you will realize that the stuff is tough. The same thing about thinking it would break if turning on a vertical hydrant, no, 1 inch black pipe, 210psi, will not just break.
Everytime you have a PVC pipe connection, is every place you can have a leak. (probably every 20 feet if you get that length pvc.)
   / Plastic pipe for underground? #32
I have 1.25 inch line that runs from the cottage downhill about 300 feet to the boathouse, then turns around and comes back uphill a little over 200 feet to a second cottage which is approximately 10 feet lower than the first cottage. So there is no uphill pumping and in fact we gain a little bit due to the second cottage being lower than the first.
We use well water that is pumped into the first cottage with a 10 gallon per minute pump, then runs through the UV/ filter system, then a bunch of half-inch pex line with several fittongs, until it exits the cottage on the other side, where is connected to the 1.25 inch black poly pipe that goes down to the second cottage.
Anyone see any problems with this? We seem to get plenty enough water flow and pressure at the second cottage.
   / Plastic pipe for underground? #33
as soon as i say i haven't, i will have problems! get the pipe in ground a couple feet or more. and you should be ok, and be at risk like everyone else is.
my worries would be pipe only being in ground a few inches, and being right in the roots of the yard/lawn, were grubs / worms and like would be, and the food source for the critters.
   / Plastic pipe for underground? #34
yes and no....
if it is just your family, and not renting or like the cottages no biggie. but if renting. i would most likely have an issue, with water pressure and GPM of water.
well with well pump -> cottage 1
cottage 1 -> check valve -> UV / Filter system -> well pressure tank -> TEE
TEE -> check valve -> pressure regulator -> to pipe work in cottage 1 (sinks and like).
TEE -> cottage 2
cottattage 2 -> well pressure tank -> check valve -> pressure regulator -> pipe work in cottage 2 (sinks and like)
above places a well tank at each cottage, to help with keeping water pressure up were it needs to be, and help some what with water hammering effect.
in cottage 1, skipping all the 1/2" pex and running 1.25" directly off of the UV/ filter system / well tank. and directly to cottage 2. you get away from extra pressure loss inside cottage 1 feeding cottage 2.
if cottage 2 turns on water and has it running for a couple minutes, and then someone turns on water in cottage 1, cottage 1 may not get any water what so ever, and possiblly get air sucked into the pipes, or a siphon happens and dirty nasty water gets sucked back into the drinking water lines. with pressure regulators and check valves. the issue goes away to a good extent. to point cottage 1 and cottage 2 regardless of who is using what water and amount, will still get some water with the pressure regulators. and check valves just keeps everything going correctly in case something happens.
   / Plastic pipe for underground? #35
When I first showed up on my own place it had a few hundred feet of black poly pipe buried to code from a pond pump site to the garden and outbuildings. I kept thinking there was a leak. I found it, some mole, vole or gopher or mutant satanic creature had chewed through it. Oh boy I thought, I hope that doesn't happen again. Well it did, numerous times. I dug it out and replaced it with 2 inch PVC and it was the best investment I could have made. Years later, I added a quarter mile of PVC, to the system and tied it into other water sources. In western Oregon, critters WILL eat the poly pipe. It aint a question of if, but when. PVC thick walled pipe has never failed me underground. I wouldn't however, bury PVC valves. If you are going to bury valves or shut offs go brass or bronze. PVC valves can fail and you can't fix em. You have to cut them out and replace them. If you are going run the pipe over ground, I would paint the stuff to cut down on UV penetration. You could get Banjo fittings and use them on your PVC above ground and you could move or take the pipe down anytime with out damaging anything.
   / Plastic pipe for underground? #36
andddd another thing. I know once in a while Napa Sonoma gets a nasty freeze, once in a blue moon. You will never regret buying USA made frost free hydrants. I have them all over the place and they are flawless. China ones not so. USA. When you install your hydrant or if you choose conventional riser and valve, use two street elbows between the upright pipe and the feed pipe. In other words do not install your up right directly into a Tee or elbow. If you don't know what a street elbow assembly set up is, ask or look on the net. Basically it is two, elbows that have screw threads, male and female. You screw those into the SCREW fitting on your supply pipe. This double street elbow set up will allow easier replacement if you have to, and it will take any stress you might put on the upright by hitting it or ground heaving.
   / Plastic pipe for underground? #37
And just to note, he is referring to the schedule of the pipe (20,40,80)... you will see 'foam core' pvc that has a thick wall but it is NOT pressure rated so you do not want that stuff. Also, at the range someone ran schedule 20 for all the outside hydrants. Now when you go to work on the stuff or tap in it is like working with glass. Frustrating to be trying to cut the stuff with a saw and it just keeps cracking further and further back on the line. Schedule 20 is cheaper but I wouldn't use it after my experiences with it.
   / Plastic pipe for underground? #38
So far I have used only copper L
Found a deal on 500' of soft copper L and bought it plus a couple 100 feet of 1" soft copper...
Hope is a one time project.
Now I have the area around the homestead done... I still need to address the mix of old galvanized and PVC with much of it surface run for 800'
Terrible gopher and ground squirrel problem here... so this why I went only copper so far.
As to pressure from the spring... it's 50 psi
Turn on one hose and it drops some... turn on two garden hoses and the flow is dramatically cut...
Gophers eat PVC as well as HDPE? :eek:
The gophers around here are so bad that .... Luther Burbank gave up and abandoned his experimental farm that was once near me.
(He started a new farm 10 miles East and donated the failed land to the cemetery district. :) True story.)
Maybe I should re-think this whole idea of plastic pipe. My North Bay and your East Bay terrior (fancy word) are approximately the same.
   / Plastic pipe for underground? #40
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
LOT: Better Built Heavy Duty Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Better Built...
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
IRON FORCE IMPACT SET (A58374)
IRON FORCE IMPACT...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
