Cleaning air filter
   / Cleaning air filter #1
Itawamba1
Fulton, ms
Massey ferguson 235
I have no air compressor. Could I just clean the outer air filter of my MF 235 with a water hose, let dry, reinstall, and keep on ranching?
Bob W
   / Cleaning air filter #2
Bob W
Use a shop van on either BLOW or VACUUM, works good enough with no compressor. Water will deform the filter media and if too wet blow a hole in it, and what's not cleaned will tuen into hard mud like cement darn near, so no air gets through after the water wash.
Thanks so much. Bob w
   / Cleaning air filter #4
Most OEM specs say to just tap the filter gently on the tire while rotating it to dislodge loose dirt. That will work to remove enough dirt for the filter to be used again.
   / Cleaning air filter #5
Just reread this, While rotating the filter, not the tire. Just so everything is clear.
   / Cleaning air filter #6
Is there any Aggies on here ? Just sayin'
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
golf cart (A55787)
golf cart (A55787)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
