Cleaning air filter
   / Cleaning air filter #1
Itawamba1
Fulton, ms
Massey ferguson 235
I have no air compressor. Could I just clean the outer air filter of my MF 235 with a water hose, let dry, reinstall, and keep on ranching?
Bob W
   / Cleaning air filter #2
Bob W
Use a shop van on either BLOW or VACUUM, works good enough with no compressor. Water will deform the filter media and if too wet blow a hole in it, and what's not cleaned will tuen into hard mud like cement darn near, so no air gets through after the water wash.
Thanks so much. Bob w
   / Cleaning air filter #4
Most OEM specs say to just tap the filter gently on the tire while rotating it to dislodge loose dirt. That will work to remove enough dirt for the filter to be used again.
   / Cleaning air filter #5
Just reread this, While rotating the filter, not the tire. Just so everything is clear.
   / Cleaning air filter #6
Is there any Aggies on here ? Just sayin'
CATERPILLAR 308E2 CR EXCAVATOR (A52709)
CATERPILLAR 308E2...
2005 MERCURY Grand Marquis (A56859)
2005 MERCURY Grand...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
2023 Kubota Z252KH-54 Zero Turn Mower (A55315)
2023 Kubota...
