No oil on air filter precleaner?
   / No oil on air filter precleaner? #1
Eric102
Gold Member
Pacific NW
John Deere 3320 John Deere X739
Just noticed this in the X739 owners manual, "do not oil air precleaner" Is this something new to John Deere?
Every small engine I've had in the past has required the precleaner to be oiled. Is this a EPA thing or because the engine is fuel injected?
   / No oil on air filter precleaner? #2
You talking about the foam stretch pad added to the air filter?
I've never heard to oil them, and would not as oil would restrict air flow... in my opinion.
Any manuals suggest oiling them?
   / No oil on air filter precleaner? #3
Oil the foam filters.
About Foam Air Filters
Small Engine Foam Filter
The “foam only” style air filter system works by trapping dirt and debris through the use of motor oil spread throughout the oil foam holding medium. A dry or non-oiled oil foam filter will trap only the largest particles. If the air filter element is foam only, it MUST be oiled and serviced regularly. Your foam filter requires replacement every 3 months or after 25 hours of use, whichever occurs first, more often under dusty conditions.
Yep, the foam filter that goes over the main pleated paper air filter. All my previous mowers, pressure washers, rototillers etc said to oil the foam prefilter. This is the first one I've had that said do not oil the pre filter.
   / No oil on air filter precleaner? #5
A search for more info, shows that motor oil should not be used, but that air filter oil made just for the foam filters is recommended.
I figure the foam is only to take out the larger particles, and the paper filter under will remove any smaller particles and last longer if not plugged up with the larger.
But in the end, I still won't oil the foam pre-filters. But don't have a problem with anyone who wants to do the oiling. ;)
   / No oil on air filter precleaner? #6
In years past they said to oil the foam wrap around the paper filter. the problem is people tend to over oil the wrap which then causes the oil to get absorbed into the paper filter clogging it up. So about 3-4 years ago they started saying do not oil the wrap, just the foam only filters. Was discussed in my Kohler update seminar a few years back.
   / No oil on air filter precleaner? #7
That makes good sense. Thanks Randyt
   / No oil on air filter precleaner? #8
True, very, very light coating of oil. Try a teaspoons worth then squeeze, squeeze, squeeze, etc........
   / No oil on air filter precleaner? #9
Our John Deere dealer said there where tons of issues where the mowers would not start and run because of the oil on the outside of the filter. They now tell all there customers not to oil them. My dad had this issue and did not use much oil. Now no issues after doing what the dealer said.
   / No oil on air filter precleaner? #10
Had a customer last year with a troybilt rider that they had left so much oil in the wrap that the paper filter was saturated, and I could squeeze oil out of the wrap. Must of been half a cup of oil come out of the wrap.
Blue Diamond 103709 (A53317)
Blue Diamond...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
John Deere 612C Corn Head (A59814)
John Deere 612C...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
24ft Equipment Trailer (A57453)
24ft Equipment...
