No oil on air filter precleaner?
   / No oil on air filter precleaner?
Must have been a lot of "user" oiling errors out there, my JD 318 has ran fine for 27 years with an oiled foam pre-cleaner and normally I'd only clean it once a year. It would be caked with dirt at the end of the season but the paper filter remained clean and I'd usually go 3 or 4 years between changing it. When oiling the foam filter I'd always squeeze the crap out of it until no oil oozed out of it.
I'm hesitant to go with a dry filter because it seems like it would let a lot more dust through to the paper filter.
I wonder if the warranty would be voided on my X739 if I oiled the pre-filter?
   / No oil on air filter precleaner? #12
I think it was the material they started using was allot finer that even hardly any oil would plug them. We have used many filter in the past that required a little oil and no issues.
Must have been a lot of "user" oiling error out there, my JD 318 has ran fine for 27 years with an oiled foam pre-cleaner and normally I'd only clean it once a year. It would be caked with dirt at the end of the season but the paper filter remained clean and I'd usually go 3 or four years between changing it. When oiling the foam filter I'd always squeeze the crap out of it until no oil oozed out of it.
   / No oil on air filter precleaner? #13
If you want to oil it, go for it. The worst that could happen is the paper filter clogs and you have to buy another one along with a new foam outer.
   / No oil on air filter precleaner? #14
Why would the paper filter clog? A PROPERLY oiled prefilter will keep more dirt from getting to the paper filter. A SMALL AMOUNT OF OIL. No pores in the foam should be filled with oil, just a VERY light coating.
NEW Fork Extensions (A59000)
NEW Fork...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
ASSET DESCRIPTIONS & CONDITION (A58017)
ASSET DESCRIPTIONS...
2014 JCB 930 (A57148)
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
