BX Power bagger question (last one for a while, I swear)
   / BX Power bagger question (last one for a while, I swear) #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
This is probably a stupid question, but the BX baggers (and all others I have to assume) mount to the 3pt hitch arms. Since the deck and 3pt is controlled by the same valve, the bagger obviously moves up and down with the deck/3pt. Since the deck moves 3-4" to the 3pt arms foot or so, how is that difference in distance handled?
I'm thinking of putting together a DIY ghetto bagger set up of some kind, which is why I ask.
   / BX Power bagger question (last one for a while, I swear) #2
The later baggers do not mount to the 3pt hitch, mine mounts to plates that are bolted to the frame. I have read that this style is much easier to mount. The movement in the deck is corrected by the flexible hose between the deck boot and the impeller driven by the rear pto.
   / BX Power bagger question (last one for a while, I swear) #3
I bought a third party bagger and mounted it to the three point hitch hanging the arms with chains from the fixed mounts. It works very well.
   / BX Power bagger question (last one for a while, I swear) #4
I have a Kubota 3 pt hitch bagger. Mounting it requires that you remove the links from the 3 pt hitch that normally attach to the tractor lift arms. That way it is possible to raise /lower the mower deck while the bagger maintains a fixed position. The bagger manual covers this in detail.
Ah - I see! Is that a PTO driven auxiliary fan? Cool if it is. Who's the 'third party'?
Got it - thanks!
   / BX Power bagger question (last one for a while, I swear) #7
Third party bagger? Please provide more info as make and model. Thanks
   / BX Power bagger question (last one for a while, I swear) #9
I had a BX22 with a nagger and my dad has a BX23 with the same set up. The bagger is pinned it at the top where the top link would usually go. The lower arms are tightened up via the turnbuckles and because the 3ph has no down pressure, the bagger does not move. The deck does, the bagger does not. The wishbone is what goes up and down with the deck, and the links between the lift arms and the wishbone are not used.
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A53424)
Year: 2017 Make...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
