Santa Craig Cringle
So I'm finally getting a chance to do some work on my tractor. Putting the front loader on hold for now - Well, more like I have to because right now I'm not getting anything done when it only runs a few minutes at a time before dying. Essentially, it fires up like a champ, warms up, I can drive it around 3-5 minutes and then kaput. Just dies and (usually) won't restart. Have run the battery down a couple times trying to restart it. After I walk away I can come back a couple hours later and it fires back up again only to repeat the same thing.
My guess is that due to the amount of rust in the sediment bowl each time it dies is that I have a rusty fuel tank, valve, and/or an air leak in my hose. There is no fuel filter between the tank and the carburetor.
So to start with I'm going to clean out the fuel tank & valve, line it, replace the hose, and install a fuel filter.
Step 1 - Drain the tank. Check.
Step 2 - Remove the hood. How in the world do I do that?
The shop manual and owners manual which I have have no clear instructions for doing so. Please speak in layman's terms because I am neither a mechanic nor all that familiar with tractors anyway. I removed the four large Philips screws on each side of the SOS control. From there, it appears I have to remove the PTO control knob, and at that point, I'm not sure where to go from there.
