Is 3039R Worth the Cost Over 3033R ?
   / Is 3039R Worth the Cost Over 3033R ? #1
bigcut
SC PA
Garden Tractor
Looked at the specs on both. Single largest difference for the 3039R is a few HP over the 3033R. Everything else is pretty much the same.
Question is it worth the few extra thousand dollars $ in your opinion.
John
   / Is 3039R Worth the Cost Over 3033R ? #2
What brand are you asking about? LS makes an R3039, and a G3033, but they are pretty significantly different in capability. I'm not familiar with a 3033R.
Sorry, the brand is John Deere.
   / Is 3039R Worth the Cost Over 3033R ? #4
D'oh....wasn't thinking Deere. For what they charge for either of those two I'd get a lot more tractor somewhere else.
Between those two, the extra 6hp (less at the PTO) might let you run one size larger implements....other than that there isn't much benefit.
   / Is 3039R Worth the Cost Over 3033R ? #5
At times i regret getting my Kubota L3200 instead of a L3800. 2,500lbs otherwise identical tractors with 32 vs 38 hp. Pushing it with the tiller I'm very limited by hp. I have also stalled it more than a few times loading at the pile. HP at the pile wasn't an issue until i loaded my rear tires though. before that i was traction limited. A couple times running a 5' rotary cutter i've had to slow down due to things starting to bog down, but not much.
My HST burns off 15% of my HP compared to a gear drive, but i still prefer HST, even with that hit.
   / Is 3039R Worth the Cost Over 3033R ? #6
No matter what tractor you have, there will be second guessing and grass greener on the other side. In my opinion, stalling from time to time is something that I can live with. L3200s are nice machines.
Gman,
That's kinda what I was thinking...The specs. are the same...even the lift capacity is the same...so other than having a few additional Horses...I don't see any strong motivation to cough up a few grand more.
JOhn
   / Is 3039R Worth the Cost Over 3033R ? #8
Just a correction in your figuring though Fallon. You hydrostatic isn't costing you 15% it's only 5.62% which is a huge difference. Tractordata.com has a L3200 hydro at 25.2 pto hp and a gear at 26.7 pto hp. That's only 1.5 hp difference.
   / Is 3039R Worth the Cost Over 3033R ? #9
That's Kubota driveline efficiency for you :)
10-15% is about average.
   / Is 3039R Worth the Cost Over 3033R ? #10
Actually I believe the larger losses are generally considered at the draw bar. You know power to the ground and all vs a gear drive . So while the PTO horse power loss is not so drastic, I believe that power to the ground is. But then maybe I'm wrong and Kubota has that superior driveline that Messick mentions. ;)
CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
CATERPILLAR M322F...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Commercial truck Frame with Axle (A59230)
Commercial truck...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
