Glueing Magnets to Aluminum Strip
   / Glueing Magnets to Aluminum Strip #11
I just snapped a couple of pics of mine. image-781574844.jpg image-2821378051.jpg I used vice jaw protectors containing rare earth magnets. Terry
Terry... Very Cool
BTW, just went to Victoria for my birthday. Never have been. Took the ferry, stayed downtown by the docks. Great food, really nice people and a beautiful city. Got out into the countryside a bit, saw the Buchart gardens and got a once in a lifetime orca sighting where Pods J,K, and L all got together. A really nice way to cover up a really crappy birthday.
   / Glueing Magnets to Aluminum Strip #13
How about locating some magnets with holes in them? Then you could use small countersunk
bolts, and nuts.
That's what I use. I get the 2-hole rectangular Neodymium magnets directly from China, which mines virtually all
the world's supply.
I have had no luck getting the magnets to stick with epoxy, even after sanding the magnet's surface.
   / Glueing Magnets to Aluminum Strip #14
I suppose I should clarify that in my case the magnets were already embedded in the aluminum jaws and I only had to adhere aluminum to aluminum with the JBWeld.
Woodlandfarms, I'm glad you enjoyed your visit to Victoria.
Terry
   / Glueing Magnets to Aluminum Strip #15
You might try 'sanding in".
Take some sandpaper and sand the magnet while coated with the epoxy. Makes a big difference with aluminum. Also make sure you have mixed your epoxy enough. Most epoxy failures are due to inadequate mixing.
   / Glueing Magnets to Aluminum Strip #16
At the risk of sounding like an advertiser... I have had great success with Click Bond adhesive bonding to magnets. You can get small kits from electricalhub.com. CB200 is the name of the adhesive... it is a fast curing two part acrylic/epoxy blend. The kit name is CB92.
CB92 Adhesive Mixing Kit
   / Glueing Magnets to Aluminum Strip #17
Im interested in this thread as well. The magnets always fall off my stainless magnet trays and I haven't found anything that works, including jb weld.
But for the op, is there a reason that you can't just use steel strips? I also wonder if the magnets would have am effect on the cut?
   / Glueing Magnets to Aluminum Strip #18
E6000. You can make glass to glass water tight and strong and any thing else. Can't use it around fuel though.
Mike. I had to make a 4 ft edge. Steel would be too heavy.
Jw. What us e6000
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
1266 (A50490)
1266 (A50490)
2015 Ford F-450 Bucket Truck (A53117)
2015 Ford F-450...
2018 Infiniti Q50 Sedan (A51694)
2018 Infiniti Q50...
