410B injector pump problem
   / 410B injector pump problem #1
jim22
Ashland
1985 John Deer 410B
Fuel injector pump will not throttle up. Starts and idles fine. But if you try to operate hydraulics. Engine will bog down or even stall.
   / 410B injector pump problem #2
Have you checked for good fuel flow from tank to inj pump?? It's possible the lift pump could be bad.
Yes New pump and filter.
   / 410B injector pump problem #4
Check fuel return line fitting that screws into pump for blockage. Simple test is loosen screws on timing window on inj pump,pry rubber gasket loose,crank engine to see if that makes a difference.
Thanks problem solved.
SCAN TO RECEIVE TEXT UPDATES (A57193)
SCAN TO RECEIVE...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
9202 (A50322)
9202 (A50322)
BOBCAT T550 SKID STEER (A52707)
BOBCAT T550 SKID...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
