410B injector pump problem
   / 410B injector pump problem #1
jim22
Ashland
1985 John Deer 410B
Fuel injector pump will not throttle up. Starts and idles fine. But if you try to operate hydraulics. Engine will bog down or even stall.
   / 410B injector pump problem #2
Have you checked for good fuel flow from tank to inj pump?? It's possible the lift pump could be bad.
Yes New pump and filter.
   / 410B injector pump problem #4
Check fuel return line fitting that screws into pump for blockage. Simple test is loosen screws on timing window on inj pump,pry rubber gasket loose,crank engine to see if that makes a difference.
Thanks problem solved.
40 ft. Shipping Container (A55973)
40 ft. Shipping...
2011 GMC Sierra Ext Cab 4X4 Pickup Truck (A55852)
2011 GMC Sierra...
2014 Chevrolet Tahoe 4x4 SUV (A55853)
2014 Chevrolet...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2024 WITZCO RG-52 LOW BOY (A57880)
2024 WITZCO RG-52...
