Quick hitch
   / Quick hitch #1
Kevin Krieger
Member
Corvallis, Oregon
Massey gc1710
I have a Massey gc1710 and was wondering what everyone was using for a quick hitch. Also I was looking at Pats easy hitch and was wondering if they fit when you put the backhoe on. Thanks
   / Quick hitch #2
Kevin, I noticed no-one had replied to this. Did you mean to limit the question to the Massey forum, or the GC1720? If not, an internal search on TBN for "quick hitch" will bring up numerous threads on the subject. Here's a recent one on the Harbor Freight model for cat 1: http://www.tractorbynet.com/forums/attachments/312766-harbor-freight-quick-hitch-issues.html
   / Quick hitch
I am wondering on the backhoe models of the Masseys if anyone has used Pats easy hitch and if there is enough room for them to stow when the backhoe is put back on.
   / Quick hitch #4
I have a GC1720 and use the Pat's Easy Change system. I am able to stow them while using the backhoe, although it is a tight fit.
   / Quick hitch
When you installed Pats easy change was it a simple bolt on with no problems? Did you need a longer top link, and would you do this upgrade again? Thanks Kevin
   / Quick hitch #7
Hi Kevin, I have same concern. I see nobody replied to your last questions. Been awhile and wondering what did you go with and results? THANKS!
   / Quick hitch
Hi Kevin, I have same concern. I see nobody replied to your last questions. Been awhile and wondering what did you go with and results? THANKS![/QUOTE
I went with land prides quickhitch QH05 and like it very much. ]
   / Quick hitch #9
Just so happens I'm buildind a hitch for my 1710 with backhoe,should finish tomorrow,I"ll snap a couple pics
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2002 Ford Thunderbird Convertible (A48082)
2002 Ford...
2016 Chevrolet Camaro 1LT Coupe (A48082)
2016 Chevrolet...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
