Adding 62D mower to a 2320 advice needed please.
   / Adding 62D mower to a 2320 advice needed please. #11
You'll also need this for attaching the front of the mower deck to the 2320. Front draft arms.
I may be mistaken but I believe that the front draft link which is also listed separately is included with the LVB25620 kit. This photo shows the entire kit:
This picture with the LVB25620 part number is very helpful, Thank You, I was wondering where that part number came into play.
   / Adding 62D mower to a 2320 advice needed please. #13
I have a 2320 with a 62D mower with the mechanical setup. If you need any pics let me know and I can supply them. It is a really simple setup.
   / Adding 62D mower to a 2320 advice needed please. #14
I just bought a used 62D2 for my 2520 and it came with the mechanical lift parts. I installed the lift, the deck, and was done in 3 hours. I took my time, and looked thru google images to find pics of the mechanical lift that I could zoom in on to see how and where the brackets went. It was super simple, but I know the 2320 mount is different. I was nervous installing it, so I went super slow and cautious. If you had a book or install guide, you could be done in a hour or so if you wanted to hurry. I just wanted to make sure I had everything right! I spent a lot of the time looking at pics online, so it took extra time, but in the end it works perfect and I'm soooo glad I bought it!
I bought a 2013 62D2 with about 5-10 hours on it for $1,300 including ALL the mechanical lift! :) My 2520 mows like crazy with it, but the JD blades are not the best. They have little lift, so they let stuff behind and the discharge plugs in really tall damp grass. I have Gator blades to try next!
Awesome to hear Deadman, that exactly what I was looking for!
   / Adding 62D mower to a 2320 advice needed please. #16
I did spend a half day cleaning the deck, and doing maintenance on it. I used a wire wheel on the bottom of the deck and then Painted it with POR-15. The factory didn't paint the bottom of the 62D for whatever reason.....
   / Adding 62D mower to a 2320 advice needed please. #17
I wouldn't paint mine... shiny steel is what I like.. :)
Will be interested in your results.
   / Adding 62D mower to a 2320 advice needed please. #18
There's a member on GTT that has a LVB25620 2320 Mower attaching parts kit for sale. It's new and unused and you'll need it if you pick up a 62D1 for your new 2320. He also has the LVB25630 Independent Lift Kit which would nice a nice option as well.
Do you know if its still available? I searched and couldn't find it.
   / Adding 62D mower to a 2320 advice needed please. #19
Yes. It's still posted in the Swap Meet Forums under "For Sale" on GTT / Green Tractor Talk. I believe you need to be a member to see it though.
Frank
   / Adding 62D mower to a 2320 advice needed please. #20
Frank
Thanks, I pm the guy this morning. I mistakenly bought a 62d2 version with all the attaching hardware. I hoping if I buy this kit I can see what I need to convert the deck over to a 62d1 version
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2017 Chevrolet Impala Sedan (A56859)
2017 Chevrolet...
