Water line trench
   / Water line trench #21
I agree. Seems like there are a lot of examples of those who like to use bigger pipes and are happy with them, but nobody who has used the same sized pipe. I'm not a fan of spending more money for something that I cannot notice the difference by spending more money. Reminds me of a buddy that I used to bike ride with. He spent $600 for a seat that was 2 oz lighter then what he had before. He was still the last one there. Spending more without any noticeable improvement is always something I try to shy away from.
How many houses have a 5/8 inch tap? Tens of millions. I wouldn't think twice about running a half in line several hundred feet.
Eddie
cheap swimming pools from local store, and filling them, filling up sprayer tank, using lawn sprinklers.... it makes a large difference. in overall amount of time to fill pool/tank up. and getting a larger spray pattern from lawn sprinklers.
and i can notice difference in pressure washers as well. what may mean peeling paint off something and actually splintering wood and holding nozzle a couple inchs away. vs having to keep nozzle 1/2" to 1/4" off of stuff to get same results of small size pipe.
some perspective... the well pump on the old small lines that i had, even small size garden hose diameters. my well pump will kick on/off every few minutes running small pipe/hose. running larger pipe/hose. the well pump stays running. and i get more GPM of water. the difference being the small lines were to restrictive.
water lines are generally a one time expensive for many many years to come. spend little extra during install. for benefits to come long term.
   / Water line trench #22
Time will move a lot of water...
We were out hand watering at the ranch and someone left a garden hose on overnight... 20,000 gallon tank was dry and mud in the parking area.
The pressure is 50 psi gravity... the flow is not great because every hose turned on cuts the flow by 50%... so with three hoses on... the water is little more than a trickle... actually, I think this is what happened... hoses were left running in the planted areas and when they were all turned off but one... the one left on was flowing at full.
   / Water line trench #23
Didnt read all of the posts, but I would go deeper too.
Technically, I think the frost line in this area is 42" or so. Not that it gets that deep, but better safe than sorry. I certainly wouldnt want to go 24".
Also, if a frost free hydrant, most have a weep hole in the bottom to let the water drain back out of the vertical pipe. So when installing, backfill with a few 5-gal buckets full of stone around the hydrant. It will allow the water to dissipate better.
   / Water line trench #24
Do it right the first time and install a bigger line than you think you will need. Pipe is cheap compared to either a) having to do it again or b) condemning yourself (and whoever else ends with the property) for all time due to an underperforming system.
   / Water line trench #26
Wow, thats quite a tank. To get 50psi from gravity the tank would need to be 125 feet in the air. At 8# per gallon, that's 160,000 pounds of water. Is this tank on the edge of a cliff by any chance?
The flow does make sense, you'd get about 10-15gpm of flow with 50psi head pressure, so that's between 15,000-22,000 gallons over 24 hours.
   / Water line trench #27
The tank is spring fed and on the top of the hill on the back 40... really, there is a back 40.
The spring is two miles away up the mountain from the tank and the land has deeded water rights dating back to 1860...
Flow is dismal at the home stead... the old 2" galvanized line with sections of 1.5" plastic repairs is about 50% surface run in the rocky area. Really cobbled together.
I'm thinking he is going to need to set aside a few dollars to upgrade... near the house the secondary tank is 2,000 gallons.
Two smaller homes on land sold off years ago from the ranch also have 600 gallon per day water rights... so nobody had water.
Can't think of any options other than metal for the exposed portions of line coming down the mountain...
No pumps anywhere which is nice...
   / Water line trench #28
All of which has nothing to do with the discussion at hand.
Unless, of course, the OP wants to sit around for +24 hours so he can water his petunias or whatever.
We're talking about getting water out of an engineered system - on a timely basis- not a water leak or someone left a valve open scenario.
Personally, I'm not going to design either on the most-probably-false assumptions - of "it's good enough" or "this is all I need", I'm going to design bases on what the current system is capable of delivering and getting the most bang for my buck.
People who design based on the lowest cost only usually end up with regret, either with themselves or the people who have to live with their system afterwards.
   / Water line trench #29
A lot depends on starting pressure and source. My rental property has 3/4 line about 500 to 600 feet from tap. I always feel like I have a Fire Hose in my hand compared to home with well and 3/4 hp pump set at 55 PSI.
   / Water line trench #30
At the plant we actually replaced a large line with a smaller one.
The building at the far corner of the property always had nasty water... old 2" iron underground line that was 850 feet long.
The plant engineer ran 3/4 PEX through the old line and no more foul smelling water.
Depending on demand, use, etc... a line too big can pose it's own set of problems.
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2016 Freightliner M2 106 Braun Ambulance (A55788)
2016 Freightliner...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
