ace10
Texas - 2 feet deep is ok.
Pa - 2 ft deep is not ok.
Exactly.
Right.
Location, location, location.
Exactly.
I have several hundred foot hoses. I regularly hook them up together to get more length with the result of a 200 foot run. I have never measured my water pressure at the end of the hose, but know that my house water pressure is set for 60 pounds. I cannot tell the difference between the water pressure coming out from the 200 feet of hose to what it's like coming out of the water spicket at the house.
Eddie
It's pointless to argue over pipe size when the project is half done and the OP said the water flow through a full roll (300 feet) was acceptable. Hopefully MoMower can answer a few questions once it's done as to how much water flow 1/2" PEX gives him.
5 gallon bucket took approx 1 min 45 to fill to over flow
Which means that a 300 gallon stock tank would take almost 2 hours to fill. I have to fill ours every other day. It takes about 40 minutes here.
Of course, if you don't have any volume water requirements now and will never have them in the future, it doesn't matter.
Thanks, if it's not too much trouble would you mind doing the same test at the faucet up by your house? I'm curious how close the calculated flow loss is to the real case.
Ok, with out the wife in the shower, or any other running water in the house, 1 gallon milk jug at the kitchen was 48 seconds.
