Tilt bed "car hauler" for CT?
   / Tilt bed "car hauler" for CT? #11
George, How does your LS sit on that trailer? Do you have to roll the loader to get it far enough ahead??
   / Tilt bed "car hauler" for CT? #12
The LS fits fine on the trailer. At 20' long I have plenty of room to move the tractor fore & aft if needed. I usually pull the tractor up so the loader bucket is within 18" from the front of the trailer then chain it down. The XR3037HC w/ loader weighs about 4600 lb so with an added implement I am at the trailers maximum capacity. My previous tractor only weighed about 4K. For the number of times I need to haul the tractor at this time the trailer is excellent. I am looking and hope to find a 20-24' Tilt trailer in the 10-12K capacity rating because in the next year or so I will be doing more hauling and don't like to haul at max capacity all the time. Will probably have to buy new because used 20-24'ers rarely come up for sale in my area. I may try selling mine and just buy a new one now but 6K or more is a buch to spend. If need be I can haul the XR in my dump trailer which has a 10K capacity.
   / Tilt bed "car hauler" for CT? #13
I am looking at this one in a 10,400# capacity. Priced it at $4,500 and i'm going to push them to toss in the remote control. Stepping up to the 14K is a LOT nicer trailer but i can spend another $1,900 although 16" tires WOULD be nice............ PJ Trailers - 83" Hydraulic Quick Tilt (TH)
   / Tilt bed "car hauler" for CT? #14
That's a nice trailer. I've looked at them before. Get the electric / hyd option (manual jack takes too long) and the larger tires and of course, a spare.
   / Tilt bed "car hauler" for CT? #15
This one comes with 6 bolt wheels & 5,200# axles with 6 ply 15" tires. It has the elec/hyd bed. I really wanted to step up to the next size with 7K axles and 16" tires but the price is WAAAAY out of my budget...............
   / Tilt bed "car hauler" for CT? #16
I don't care what anyone says, 6 ply tires are not enough for 5,200# axles. We are currently putting on 10 ply on all the 5,200# axles we have but 8 ply is enough.
The reason I go 10 ply is my cost is only $3 more per tire over 8 ply.
Chris
   / Tilt bed "car hauler" for CT? #17
Chris
My bad, Meant to say 8 ply not 6 ply. Load range D 2,450# per tire. I may upgrade to 6 bolt 16" wheels in the future as i could mount 10 or 14 ply 16's that way. Just looking for less rolling resistance.......
   / Tilt bed "car hauler" for CT? #18
Looking for less rolling resistance is not going to happier economically. I don't care if you pulled the trailer a thousand miles a week for the next 5 years you will never recoup you initial lay out.
We rin 225/75/15 10 plus on 6 lugs at 80 psi for the most bang for the buck.
Chris
   / Tilt bed "car hauler" for CT? #19
I would look at Kaufman factory direct. I have there 24 with fixed 10 foot front. Best trailer I have owned. No need for power tilt if trailer is designed correctly. Easily controlled by weight of load.
   / Tilt bed "car hauler" for CT? #20
Looked at theirs but also took the advice of a friend and got the power tilt. He has a Wilson with the cushion tilt and in the middle of winter when it's 20 below zero it hardly moves until he gets ALL the weight forward or back. That don't work so well in snow and ice and when it's muddy he has a hard time loading as well. He has been looking at the power tilt. I should be able to pull on till the back tires are JUST on the trailer, hit the button to tilt up and then roll forward on the level.
LOOK! (A53485)
LOOK! (A53485)
2013 MACK CHU613 DAYCAB (A55745)
2013 MACK CHU613...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2021 VOLVO VN SERIES DAY CAB (A55745)
2021 VOLVO VN...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
gravely riding mower (A53424)
gravely riding...
