RPK
I am considering purchasing a 3 point hitch log splitter. Maybe from Tractor Supply. I have an L3130 with a Kubota BH90 backhoe. My question is, in order to hook up the splitter would I use quick disconnect fittings and the appropriate length hoses and connect it the same as the backhoe? Another question. When the backhoe is removed the manual states that the hydraulic hoses should be connected together at the rear of the tractor. Is there a reason for this other than to keep the fittings clean or does fluid need to be flowing through that part of the system??? I'm not much of a "hydraulics guy" but I'm learning.
Thanks, RPK
Thanks, RPK
