3 Point Hitch log splitter
   / 3 Point Hitch log splitter #1
RPK
Eastern CT
Kubota L3130 Cub Cadet 1554
I am considering purchasing a 3 point hitch log splitter. Maybe from Tractor Supply. I have an L3130 with a Kubota BH90 backhoe. My question is, in order to hook up the splitter would I use quick disconnect fittings and the appropriate length hoses and connect it the same as the backhoe? Another question. When the backhoe is removed the manual states that the hydraulic hoses should be connected together at the rear of the tractor. Is there a reason for this other than to keep the fittings clean or does fluid need to be flowing through that part of the system??? I'm not much of a "hydraulics guy" but I'm learning.
Thanks, RPK
   / 3 Point Hitch log splitter #2
You will use the same QD fittings that your backhoe uses. The hose connecting the two power beyond fittings is so the fluid has a continous path back to the pump. Stop the flow more than momemtarily with the engine running and you will need to get your wallet ready. ALWAYS hook up that little short hose before starting the engine again. Shut the engine off before unhooking it.
I have the 3pt TSC unit and it works great. You will need to get some hoses for it and the the fittings to match your Kubota. Buy the hoses long enough and then add another foot or two to what you think you need for length. Too short is a pain. They need some ability to move and flex as you work. Adding a 90 degree fitting might make them route better depending upon your fitting locations. Get a gallon of hydraulic fluid at TSC if you don't have some laying around. The splitter will be empty when you get it home. It will fill from your tractors reservoir as you cycle the piston a couple times. You will then add the gallon to your tractor. They will share one fluid supply continously. When you cycle it back and forth a few times, you will be able to tell when the splitter if full of fluid. The noise will change and all will be silent. At that point you then need to fill the tractor reservoir before going any farther. It will be a gallon low.
Beware of the cheap legs. I took mine off and let the splitter hang in the air on the 3PT while working. When not in use, it sits on a furniture dolly for $10 from TSC. If you can weld, you could weld those legs on and add some reinforcement. I personally thought they were in the way anyways. Banged shins.
I use 1500-1800RPM for splitting. There is no need for a screaming engine while enjoying splitting wood. And I did mean enjoying. The sound of oak cracking after the ram goes only 2-3" into the wood is satisfying. Stop the ram, reverse it a few inches and repeat.
There are several good reasons for getting the 3Pt model:
Lower initial cost
Smaller unit to store
No extra engine to maintain (think gummy carbs once a year)
Virtually theftproof (wait till you try to load it at TSC in your pickup)
Few people begging to borrow it like a tow behind
Gordon, Thanks for your help. RPK
   / 3 Point Hitch log splitter #4
Informative post Gordon, good job. Just to add a little of my own experience, I too discovered less aggravation with the hoses when using angled swivel fittings at the cylinder ports.
And yes, the stand - as delivered - is somewhat less than sturdy. But horizontal leg braces bolted or welded about a foot off the ground make all the difference in the world.
Where you set your tractor throttle is directly related to the flow rate of the hydraulic pump. Mine KAMA pump apparently pushes more than your JD pump, as I don't have to run my 454 any faster than 1100-1200 rpm to reach full speed/power on the TSC cylinder.
Even though we bought them at TSC, the splitter is actually a SpeeCo.The operator manual is here: http://www.speeco.com/pdfmanuals/logsplittersmanual-d.pdf. Note the cycle time chart on page 10. The max gpm capacity of your tractor pump determines the cycle time. So you don't have to run the tractor engine any faster than is necessary to obtain max output of the hydraulic pump.
//greg//
   / 3 Point Hitch log splitter #5
Too late to edit my post above, but I just noticed on TractorData that the JD790 hydraulic flow is rated at 5.6 gpm. Kubota rates the L3130 implement pump at 8.3 gpm. Armed with those numbers, you need merely determine at what engine rpm the pump reaches the max flow rate. RPMs above that will likely just waste fuel.
//greg//
   / 3 Point Hitch log splitter #6
Hi. My brother in law has one of those TSC 3 pt splitters, and he really likes it. He powers it with a small Ford 1310 tractor, and runs it at about 1500 RPMs. I have a 3 pt splitter that I made myself. I'm very happy with mine as well.
I'll also second Gordon's comments about having only one engine to maintain. That is the main reason I decided to go with a 3 pt splitter. An added benefit is that listening to your tractor running at a leisurely 1500 RPMs is a lot easier than listening to a 5 horse B&S screaming only a few inches from your ears, and I like the ability to use the 3 pt to raise the splitter to a comfortable height.
Good luck with whatever you decide to do!
Corm
   / 3 Point Hitch log splitter #7
Corm is right about the working height. It is so much better to set the beam at the exact height that fits you. Your back will appreciate that at the end of the day.
   / 3 Point Hitch log splitter #8
I like mine because I can lower it almost to the ground allowing me to roll very large pieces onto it. I can then raise it to a comfortable working height.
   / 3 Point Hitch log splitter #9
I'm guessing yours isn't vertical capable. The TSC model we're discussing splits on the horizontal, but can be tilted into a vertical position to do those big chunks that are too heavy to lift.
I start in vertical, split the big stuff down to pieces weighing less than 50 pounds - but bending down to do that is hard on the back. So when all the big stuff is split into manageable pieces, I tilt back to horizontal. Makes a big difference being able to work with your back straight.
//greg//
   / 3 Point Hitch log splitter #10
Anyone using the TSC splitter on a newer 3x20 series with Power Beyond? The PB set-up on my 3320 has 3 connections--the "normal" loop, and an extra on the left hand side (when viewed from the rear). It's not clear to me how to set-up the splitter in this arrangement. If you run the splitter from the loop output and then back into the loop input (the way you would on the older version of the PB) that's fine--but what's that other connector for?? Maybe a higher flow--direct return to the tank? Any suggestions?
Thanks,
B8fish
   / 3 Point Hitch log splitter #11
I opted against the 3pt splitter just because I didn't want the tractor tied up just because I wanted to split wood.
Lots of times I am hauling wood out of the woods (3 pt rack carrying wood, and loader full), so then i'd need to rip the tractor apart just to split the dang wood up. I went with a Honda Engine model and can't say enough good things about it........
Depends how u use your tractor. :cool:
   / 3 Point Hitch log splitter #12
Thanks,
B8fish
The manual that came with the power beyond kit for my 3320 calls for using the 3rd connector for return whenever an implement is connected. This provides a direct return to the sump and by-passes the rockshaft unit so 3PH operation is disabled. The old design had only two connectors with return always passing through the rockshaft unit.
Why this change in design? I don't know. And I don't know if it is safe to use the "normal loop" return when using a splitter thus retaining 3PH operation. For everyone's information, this is being discussed in another thread, see:
http://www.tractorbynet.com/forums/showthread.php?p=1066498#poststop
   / 3 Point Hitch log splitter #13
I also am considering getting a 3 point splitter for my L2900 since I have a mountain of big heavy Maple and a 100' fir that;s 4' at the butt to split. I would need the horizontal/vertical design. QUestion I have is are all these splitters mounted sideways? I was thinking I could back up to big rounds that I cannot lift and slide the foot under the round with the tractor to split it. Doesn't seem like that would work with the splitter mounted sideways????????
   / 3 Point Hitch log splitter #14
They do make 3 point splitters in the orientation you want. Check out the Wallenstein WX370 below. However, it does not look like the hing latching mechanism may strong enough for pushing around a big round using the tractor with the splitter in the vertical position.
Wallenstein WX300 Series 3 Point Hitch Wood Splitter Specs - Wallenstein Outdoor Power Equipment Made in Canada
   / 3 Point Hitch log splitter #15
__________________________________
Looks interesting but since it is strictly a vertical splitter it has limited versatility. I suspect all of the 3 point splitters that are vertical/horizontal mount sideways for structural reasons. I just need to figure out what is the best approach to splitting the big rounds I am accumulating. I usually just use a maul or a sledge and wedges but I am almost 70 and ...............
   / 3 Point Hitch log splitter #16
It would be necessary to prop up one side of a large round in order to get the foot of a splitter such as the Wallenstein 370 under the round but it seems to me that that approach should work. I used to manhandle large rounds into position on a 3 point vertical/horizontal splitter (operated in vertical position) but I've grown too old for that, so I sold the 3 point splitter, bought a stand-alone vertical/horizontal splitter, added a grapple on my loader bucket and position large rounds onto the splitter (operated in vertical mode) using the bucket & grapple. That technique is working well for me.
   / 3 Point Hitch log splitter #17
How about a horizontal splitter with a log lifter or crane? I can't name any but have seen several of each on TBN.
Bruce
   / 3 Point Hitch log splitter #18
horizontal splitter costs a bunch more than the 3 pt and one with a lift even more. WOuld kinda eat up all my profits from the wood............ Might just stick with the maul and wedges. Once I bust one in half its usually game on. I might rent a splitter and try it out but picking up each piece to either put in on the splitter or under the ram seems like as much work as busting the wood by hand.
   / 3 Point Hitch log splitter #19
There was one on Craigslist that was upside down which allowed you to lower it onto a log lying on the ground. IIRC, it was for a skid steer, maybe there's one like it for tractors. That would be the cat's meow for big rounds. I agree though, sledge, wedges, and splitting maul are the fastest way to make the pile of big pieces into a pile of small pieces :)
KUBOTA ZG23F ZERO TURN LAWN MOWER (A60430)
KUBOTA ZG23F ZERO...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2009 Cadillac CTS Sedan (A59231)
2009 Cadillac CTS...
2393 (A60432)
2393 (A60432)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
