donnyviking
My MF was leaking fuel, found a mice nest. Fixed the chewed return lines and one fuel line from tank. Also spliced two 18ga wires. One of the wires was battery charge indicator light. Buttoned everything back up, started tractor and noticed battery charge indicator light was on. Tilled a few acres and everything was fine. Shut down tractor. Next day I tried to move tractor and it will not turn over.
I have 12v at starter and alternator from battery, plus 12v in/out of K1 relay, PTO safety switch and Neutral safety switch. I also have 12v at solenoid excitor when key is in start/crank position. I'm assuming starter or solenoid just failed, but found it weird that it was so sudden. Tied tapping the starter and solenoid with no success. One bolt looks like an SOB to remove so I thought I would post before trying to remove it. Any way to test starter or solenoid on the tractor or any other ideas on the issue?
