Yanmar 1820D Tire Adjustment & PTO Question from Washington
   / Yanmar 1820D Tire Adjustment & PTO Question from Washington #12
Have a look under the front of your seat. On mine there is a black wheel to adjust the rate of descent of the 3 point hitch. Turn it all the way anti clockwise should give you almost instant drop. If that doesn't work, I haven't a clue.
   / Yanmar 1820D Tire Adjustment & PTO Question from Washington #13
Hey welcome from another Southwest Washington Yanmar owner........I am on the other side of the hills...towards the ocean......enjoy that Yanmar!:thumbsup:
   / Yanmar 1820D Tire Adjustment & PTO Question from Washington #14
There are likely two valves on that thing that affect drop rate.
Bluest described the 'service valve' under the front of the seat. This valve should be closed (clockwise) when you want the implement to stay up forever, engine running or no. It chokes the return line from the 3-point. 99% of the time this valve should be left wide open, counterclockwise.
The other valve to look for is the 'drop rate valve'. You adjust this one to get the desired drop rate, so that heavy implements don't come crashing down. This one's harder to find. Look for a tiny t-handle likely painted red. On some Yanmars it is halfway down the left side of the transmission under the left-rear of the seat. Adjust as needed.
Here's the drop rate valve shown the manual for an older Yanmar. There is red tubing slipped over the T (L, in this case) to make it more visible.
60195d1156820929-all-us-yanmar-owners-ym3ptloweringvalve-gif
And Welcome!
   / Yanmar 1820D Tire Adjustment & PTO Question from Washington #15
Hi Rob,
I'm up in the Yelm area, just below Ft. Lewis. My 1820D will drop my 4 ft Howse Brush Hog in a matter of seconds. It must be a pressure adjustment issue. Tractor Ernie, just south of Portland, used to deal in used Yanmars and has a wealth of experience and knowledge about them. If lucky, he may weigh in on your question. Sorry I can't be of specific help on this issue. The PTO low speed, 540 rpm, is quite sufficient for the grass, weeds and brush I have to contend with.
   / Yanmar 1820D Tire Adjustment & PTO Question from Washington #16
It's not an issue of adjusting the hydraulic pressure.
The point here is how fast the trapped hydraulic fluid is bled from the lift piston after you move the lever forward.
If you open the slow return valve full open then move the lift lever forward ... your mower will crash down instantly.
   / Yanmar 1820D Tire Adjustment & PTO Question from Washington #17
According to the parts mnaual I have for the 1820 it does not have the controls Californial has described. Rather, it has only the round knob under the seat that is called a slow/stop valve. It should be adjusted toward the closed position in order to control descent speed. Open it a little and your drop speed will increase. Yours may or may not have the looped hose shown there.
   / Yanmar 1820D Tire Adjustment & PTO Question from Washington #18
Thanks Winston.
Newfangled fancy tractors! All I know is the old simple ones. But I do look enviously at the modern ones once in a while.....
Actually it makes sense that they combined the drop rate function into that stop valve since the purpose of both valves is to choke the fluid return line.
   / Yanmar 1820D Tire Adjustment & PTO Question from Washington #19
Thanks Winston.
Sure, mine is one of the newer 1982-83 2002D models. :D
2011 GMC SIERRA 2500 (A52472)
2011 GMC SIERRA...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A52472)
2008 V.E...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
