Miller 211 purchase on 8/15
   / Miller 211 purchase on 8/15 #21
The thing about cold lap (weld laying on metal with insufficient fusion) is that sometimes you can have what looks like a very good weld but in fact has cold lap and lack of fusion. That's why is always good to weave side to side or go in little circles unless you're doing thin sheet metal.
Good info, Arc. :thumbsup:
My first instructor, back in the 60's taught us to make little circles to get good fusion at the edges. Then when I started working, most guys there had been taught to go side to side. So as Arc said, either way is good.
Still have to have enough amperage, though. Or it's going to sit on top like water on wax paper. :)
   / Miller 211 purchase on 8/15 #22
Post 10 of this thread has a good photo of the results of a cold lapped MIG weld. The tooth on the toothbar is missing and as you can see it was never welded properly in the first place. Just a bead layered on top of the parent metal.
http://www.tractorbynet.com/forums/...dealing-flat-toothbar.html?highlight=toothbar
Post 1 of this thread shows a back blade that was not welded very well either. The MIG bead just did not penetrate properly.
http://www.tractorbynet.com/forums/...k-blade-needs-minor.html?highlight=rear+blade
   / Miller 211 purchase on 8/15 #24
Well I got my 211 today.......along with a few more things.Miller cart,full tank of gas,coat,gloves,pliers,10 lb roll of wire,welder cover, 3 boxes of consumables,and helmet. Also set of torches,tanks and cart. Also an 875 plasma cutter,cover and box of consumables. Total spent $4100.Plus a $100 rebate which will bring it down to $4k even. The tanks are also full. I think I did OK
That's a nice setup. You are going to like those machines I bet.
Happy cutting and welding!
   / Miller 211 purchase on 8/15 #25
Happy welding!! Will be looking forward to your Christmas Day thread.
Terry
Terry
Didn't you know that Xmas was changed to August 15th. LOL
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
NEW Woods 6ft Finish Mower (A53473)
NEW Woods 6ft...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
40' CONTAINER (A51244)
