Redneck in training
Elite Member
I didn't read all the post so I apologize if a I repeat what was already said.
I think small wind is out due to cheap solar panels. There is one good and several bad aspects of owning small wind generator.
The good:
Generates power when sun doesn't shine.
The bad:
It is generally more expensive per kWh produced than solar.
Requires preventive maintenance=expense.
The maintenance is 140 ft high=expense.
Are prone to damage by high wind, ice build up etc=expense.
last time I looked at installed cost of Bergey 10kW it was about 40,000 DIY before incentives.
If you have the space go solar. Typical warranty for 1st and 2nd tier manufacturers is 25 years, it requires minimal maintenance, the maintenance is on ground or roof of your building. Excess energy is relatively easy to store in a water tank in example for heating at night.
In either case ROI depends on contract with the utility.
Solar with similar production will cost you about 30,000 DIY before incentives.
The good:
The bad:
