Fuel line routing under the seat - BX25
   / Fuel line routing under the seat - BX25 #1
tpursell
Clayton, NC
Kubota BX25DLB
I just got my tractor back from being repaired at the dealer. They had to replace the hydraulic pump to fix a horrible screeching noise it was making (that's a whole other story...) Anyway, when I got it back, a few things seemed to be out of place. Most notably was a fuel line that was stretched under the seat. When flipping the seat forward and then returning it to its normal position, the catches get caught on the line. I am certain that is not a good thing, as it will eventually tear the line open. I don't even remember it being there in the first place. Does this look abnormal to anyone (see attachment)? Is it supposed to be tied up somewhere or routed some other way?
Thanks...
   / Fuel line routing under the seat - BX25 #2
I would say that the tech who worked on your machine got a tad lazy...I'll look at mine tomorrow to see if I can see the routing.
   / Fuel line routing under the seat - BX25 #3
Maybe make a hard copy of pic bill and swing by dealer and look at another bx25. If dealers no hose get him over and point out and have him fix/talk to tech. Course hope close by and not 200 klicks away
Yeah, that's probably what I'll need to do. I simply don't have a frame of reference to compare it against. The dealer is [inconveniently] only open when I am at work, so I'll have to leave a little early some day this week. The tech definitely messed up somewhere along the line. Also notice the wire that got crushed by the seat spring in the lower right of the picture! I won't even go into the five times it had to go to the dealer in the first 50 hours of its life... I am still confident that I bought a quality piece of equipment, but my experience so far is starting to wear down my confidence. :(
   / Fuel line routing under the seat - BX25 #5
I checked mine today and the fuel line is not on top like yours is. I would say that is incorrect.
Sorry to hear about your problems and best of luck!
That's what I thought, unfortunately. Looks like trip #6 is in order! Thanks for checking...
   / Fuel line routing under the seat - BX25 #7
No problem - if you need something else checked just yell
   / Fuel line routing under the seat - BX25 #8
Senter Tractor on 401 in Raleigh ?????
   / Fuel line routing under the seat - BX25 #9
That fuel line should be under the fender, there are two small pegs that it goes around to hold the line in place. ROPS and fenders need to be removed to properly place it.
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
