My Working Gloves Suck !
   / My Working Gloves Suck !
Gary & Two Bit - The posts are 8ft to start with which means the Atlas Copco hydraulic pounder handles are at 9ft. I'm not that tall. There is not a chuck that is shaped like the post profile for any pounder so I use the larger round chuck with a post cap so it does tilt a little bit. The pounder is ~80lbs. I could possibly use a ladder but my cycle times would go way up. I did not mention this before but I have 1400 posts to put in and I can get 70 done in a day and that is with hitting rocks and repositioning if need be. I'll dig out a pic later to share.
Picture of the gloves I have used this summer. The top 2 are Ace brand and the bottom 2 are TSC store bought. It is always the left that rips up so I have a lot of right spares. The Aces rip at the seams whereas the TSCs wear holes.
Picture of the post pounder hooked up to the tractor...
Two Bit - Yes I have. The large blows tend to bend post tops unless you have a chuck exactly fitted for the post profile. I went for the multiple fast blow style as it tends to move rocks out of the way and is post top saving. Mine I think does 1600 blows per minute. It is essentially a jack hammer technology. The other consideration for me was the Rhino PD55 but it required a significant towable compressor which jumps the cost significantly. The unit I have runs off my tractor hydraulics and I can still tow a small trailer with the posts I need to pound.
   / My Working Gloves Suck ! #36
I like the goat skin gloves.
   / My Working Gloves Suck ! #37
You've got it well thought out and every base covered. :thumbsup:
Except for a good pair of gloves. :confused3: :)
   / My Working Gloves Suck ! #38
Got any videos of it in action? Would like to see it work. Who makes it?
I appreciate all the replies thus far. Based on the responses I have on order for delivery tomorrow are a pair of the inexpensive rubberized kevlar gloves and a padded Lamont cowhide front and fabric backs. For the metal posts I'm pounding at the moment I find that the stitched seems are the problem and holding the post while being pounded slides the metal down the glove. If the kevlar gloves don't work out as planned I can use them for shucking oysters.
Update - The Lamont leather gloves mentioned above got a cut within 4 hrs of use. The less expensive rubberized kevlar gloves are performing well so far.
   / My Working Gloves Suck ! #40
thanks for the update!
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
KUBOTA ZD1211 (A53084)
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
434668 (A51572)
434668 (A51572)
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
