What size chain binders and chains?
   / What size chain binders and chains?
I would rather use 4 of the 3/8" gr. 70 chains than 6 -5/16" any day. I also use the 9200 # rating ratchet rather than the lighter ones (5200?). Legally you have to have a separate chain & binder for each corner. You cant use one chain and 1 binder for each side (or front /rear) of the tractor, so yes you need 4 short chains and 4 binders plus a chain or strap to hold down each attached implement like FEL, backhoe, bush hog, box blade etc. You use your binder to take up the middle slack in a chain, each end of the chain is attached to trailer/equipment.
Thanks Gary. Good info!
   / What size chain binders and chains? #12
image.jpgimage.jpgimage.jpg. I have used these hauling heavy equipment before. You never need to worry about a handle rattling into a tight spot and getting stuck, that being said don't set the handle down to tie on your wide load signs and forget it, of course that is just a hypothetical scenario.
   / What size chain binders and chains? #13
Here's how everyone does it around here 2 short chains in the front hook that up and back up till their tight then put your longer chains in the back and put your binder in the middle and wrap the extra chain around it to make sure it dosent pop open also when you close your leaver binder give it a good hit it will lock it
   / What size chain binders and chains? #14
I plan to replace my ratchet strap binders with chains and ratchet load binders. I tow a 70 horse Kubota on a gooseneck and normal implements like rotary cutters, etc. I'm thinking about the ratchet style rather than the lever style. Looks like Northern has all I need. What size chains? 5/16 or 3/8? And I assume I need grade 70 chains? Any tips or advise?
Don't ignore the BB hardware stores for chain. I got my first 6? chains from Home Depot and it was less expensive than Harbor Freight. I'd recommend you carry at least 1 lever style. If you are only loading a tractor and a bush hog you may not need it, but sometimes I've found that the lever (w/ handle tied) fits where I found it "tight" to swing the ratchet. I've also used lever types on one end, hooking them up first, then ratchet types on the other end to make the load squat.
   / What size chain binders and chains? #15
andre, You need to drop the hoe to the deck and secure it. Be careful tying down over your ramps, you might end up with a kink in the ramps over time or after a hard stop.
   / What size chain binders and chains? #16
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=388060"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=388061"/>
I would put two chains in the back vs one. Last thing I want is that tractor coming through my cab in a crash.
Chris
   / What size chain binders and chains? #17
andre, You need to drop the hoe to the deck and secure it. Be careful tying down over your ramps, you might end up with a kink in the ramps over time or after a hard stop.[/QUOTE
I stopped at our local scales (MTO) and ask they said I don't need to because theirs a way to lock it both up and side to side and I'm not to worried about the ramps bending they weigh about 400 pounds a piece
   / What size chain binders and chains? #18
And ya always 2 chains and 2binders in the back
   / What size chain binders and chains? #19
Also, a word of caution when it comes to lever-style binders...when unlocking them, they can kill.
A local guy around here died from head injuries sustained by a length of pipe that was used to unlock a lever-syle binder. There was so much tension on the binder that it whipped the pipe into his head.
Grade 70 chains and ratcheting binders for me.
   / What size chain binders and chains? #20
If you are worried about cam/lever binders backlashing when releasing them, get a cheater bar for this style of binder. It has a release bypass so it won't backlash. Available a most truckstops. I warned and then watched a guy break his leg while releasing a lever style binder. If he would have listened he would have been fine. There is a right way and many wrong ways of doing things. Right now I am stuck with 3/8" G 70 chains but I am replacing them with 5/16" ones as I go. I am keeping all of my 3/8-5/16" binders and gave away/sold all of the ratchet binders I had. The only time I have ever had a snap binder come loose is when it was not bound down correctly and loosened up allowing the binder to open. CJ
edit. 2 separate tie down points and binders in the back, 2 in the front [sometimes I cheat and do 1] Then small straps for each implement. DOT regs say even your bucket that is attached to the loader has to have separate tie downs. Like I said I just use small straps but it is legal. Don't need any grief with a CDL license.
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
2010 Kubota ZD326 60in Zero Turn Mower (A55851)
2010 Kubota ZD326...
2017 Ford Taurus AWD Sedan (A55853)
2017 Ford Taurus...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2012 FORD F-550 SUPER DUTY (A55745)
2012 FORD F-550...
CAT 420D IT (A47477)
