Pump timing
   / Pump timing #1
International624
Nsw
624 international with do6 engine
Hello there fellow international owners ! What is the correct injection pump timing on the 624 international tractor there is a 3 a 4 and 706 stamped on the cog ? Any help would be greatly appreciated have set it to 4 an it will start on ether but will not idle.
   / Pump timing
Hello there anybody with any info please
   / Pump timing #3
I had a 624, and the previous owner had rebuilt the engine. He told me that the injector timing was a bear, but I never had it apart myself. I had the engine service manual, which described it in detail, however I sent it on it's way with the tractor when I traded up. They're available here: Parts for International 624 tractors
Good luck!!! If it starts on ether, you may just need to bleed the fuel system some more...The 624 is a workhorse, I would still have mine if the parts availability was better.
Sent from my LGL35G using TractorByNet
   / Pump timing
Yeah I rebuilt the engine myself as well! The pump **** it self an I got an aftermarket one I definately have all air out of system just need correct timing I appreciate ur response mate thanks a million the red engine manual that comes up on your link is definately the manual with the timing in it yeah ? Thanks once again mate
   / Pump timing #5
Yes, it's the manual that I had with my tractor. It's very detailed. Should be relatively easy to follow. Let us know how you make out with it. Sorry I didn't have the information off the top of my head, but the manual will definitely be invaluable if you plan on keeping the tractor for a long period of time.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
Towable Dewatering Pump (A59228)
Towable Dewatering...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
